Actually a Yamaha SA2200.
I really don't like the high frequency inductive buzz you get when you take your hands off of the strings / metal parts.
On a Strat or a Les Paul its easy: apply foil / graphite paint to the cavities / rear of the pickguard and create a conductive 'Faraday Cage' around the electrics, then no more buzz (it of course has no effect whatsoever on 50Hz hum, which is a totally different thing).
But how do you screen an ES335?
And if you have 4 conductor wiring and push-pull pots for series/parallel switching - with those 4 little wires floating around, does that make it even more difficult?
30cm Jack lead - coupler - 2m Jack lead to amp
If I lay the coupler on my bare skin, voila...! Nicely screened, no inductive buzz (pic below)
https://i.imgur.com/j7SE46P.jpg
I could use one of these devices, but there is nowhere on a 335 to safely attach it without scratching. It would work beautifully on a Stratocaster or telecaster though...
https://i.imgur.com/SlA5uf4.jpg
https://i.imgur.com/TIH9cHP.jpg
In the 60s and 70s Gibson used to put metal shielding cans on the pots, with all the unshielded wiring and the tone caps inside, but they're a massive pain if you ever need to work on the wiring. The Gibson-size ones wouldn't fit switched pots either.
Worse, I've also seen some guitars which have splittable humbuckers where the split wire is an extra, unshielded wire *outside* the braided cable to the pickup - I don't think it's Yamaha though.
Proper shielding isn't rocket science - it's a bit surprising that guitar companies still can't get it right after 70 years...
It would probably be possible to spray shielding paint into the cavity, but it's a big job as it would need the whole wiring loom taking out and the front of the guitar masking to stop any accidental leakage - the sort of thing that's easier done when the guitar is made than afterwards.
The harness I took out of my ‘82 Gibson 335 was all screened cable and none of the unscreened connections of cloth-covered core were longer than 15mm, most were shorter. The only longer unscreened ‘wires’ were the legs of the two ceramic tone caps.
The replacement harness was made similarly but with better components so there were no unscreened cables to cause any noise.
If your push/pull pots were wired competently the small extra unshielded connections shouldn’t be an issue but it looks like you have some fairly long unshielded wires in there.
BTW, seeing how some of the other wiring looks, have you checked that the bridge is properly grounded?
Obviously, in a circuit with partial/“tuned” coil splittage - as often now practiced by PRS themselves - this method is probably introducing some noise unnecessarily.
Like in this Seymour Duncan diagram below, 'solder the red and white wires'. They're still unscreened right? Okay in a well screened Les Paul, not so much in a 335...
And so even in full humbucker mode, the signal is passing through the series connection, and is prone to picking up 'interference'?
Anything I can do besides keeping the wires as short as possible?
Or is a braided two conductor wire fundamentally superior?
[Imgur](https://i.imgur.com/m9sKqJR.jpg)
For clarity they are not showing all the screening but, for example, the wires from the pickups would be screened right up to as close as possible to the p/p switch connections. Likewise, the wires from the pots to the sector switch and from that switch to the output jack would all be screened. It's all about good harness design whereas the SD diagrams are simplified. If those wires were not screened you would pick up a lot of noise and, as you have found, screening any sort of hollow body electric is more than a challenge so that is why screened cables are a must.
Edit: I have not checked that SD diagram and, as @Funkfingers has sometimes mentioned, they are not always accurate!
Looking at the diagram doesn't the screening for the pickup cable stop where the black bit ends?
After that aren't they merely bare red, black, white and green wires with insulation but not screening?
Till now, I've been under the impression that for a wire to be screened, it needs to be 'coaxial' (i.e. enclosed within a conductive screen, which is connected to ground)
Since none of the four coloured wires any longer have that screen (beyond the point marked by the arrows in the pic below) I would imagine that they are not screened...?
Happy to be corrected...
[Imgur](https://i.imgur.com/PgOYhss.jpg)
In the morning I'll post a screened harness photo so that you can see that the unscreened wires are so short as not to contribute any significant noise. If SD drew them that short it might be difficult to see which wires are connected to what.
I thought it was PRS. It’s a really stupid way to do it and certainly introduces at lot of noise - the split wire is basically an aerial connected to the coil junction.
They also used about 8” of plain wire between the controls in my Hollowbody - it buzzed like a wasps nest until I redid it properly with shielded cable...
https://www.thefretboard.co.uk/discussion/186419/yamaha-sa2200-violin-burst-in-excellent-conditon-with-hiscox-pro-ii-gs-case-1000#latest
No wires visible in the f-hole.
I'm very sure jaymenon's one has been messed about with, but I'm not totally certain it's the cause (or the only cause) of the buzz.
Another thing I've noted is that @jaymenon refers to series/parallel switching with push/pull pots whereas Yamaha says the guitar has coil taps via push/push tone pots. A change in specification perhaps? Or did someone rewire the guitar?
But they are very much push-pull pots (not push-push, which I much prefer)
