Check out Focusrite, Audient and SSL but there are loads of different options.
Are you Mac or PC?
What budget do you have in mind?
The other thing to look for, when considering latency, is the ability to support Direct Monitoring. The latency is introduced because the incoming analogue signal, from your guitar or mic, is digitised and processed by the computer. The time taken to do this depends upon a few things (the audio interface itself, the computer and the drivers) but anything more than a few msec and it becomes noticeable (some people are more sensitive to it than others). If you have direct monitoring you basically hear the incoming signal, before processing, mixed in with playback. This means that you can run with large buffer sizes (which reduces the frequency of pops / dropouts during recording and also means that you can get away with a lower spec computer). The downside is that you can’t hear any plugin effects during the recording process.
Until you get into this you are not really going to know what will work for you but it’s probably worth having direct monitoring on your wish list.
Also, think about how many inputs you will need. This will be driven by the maximum number of tracks that you need to laydown at one time. If you are just recording yourself then more than likely 2 will be sufficient.
There are times you want to monitor with effects- this is why DSP-based systems like HDX and UA are favoured at the professional level.
One of the best companies who do extremely low latency drivers are Presonus.
RME are very good too.
Check out the Focusrite Scarlett devices, they start around £100-150 ish I think.
I’ve never used one but they are ubiquitous and people seem to like them.
I reviewed some recently and latency very good.
RME also have totalmix for hardware monitoring as well.
I'm using an SSL2+ at the moment, but it's just two channels.
R.
Eqd Speaker Cranker clone
