It's all about the context and what you're trying to achieve.
The idea that volume and sustain are directly related to flexibility and stiffness. That’s fundamentally an assumption.
Many factors will affect sustain and it’s by no means a proven fact that stiffness and sustain are in direct proportion. It’s a much more complicated equation.
Soundboards made of tonewoods are naturally stiffer along the grain than across it. This poses problems for steel string guitars which the traditional X-bracing solves by redistributing crosswise stress. Fan bracing does something similar.
The first part, however, is that it is a very practical and sensible way to deal with the great, fundamental structural weakness of the traditional flat top guitar - i.e., that we put a bloody great soundhole in the top under the strings, right where it needs to be strongest. Taylor's V bracing produces a naturally stronger, better-engineered design, which means that the top can be lighter, or stronger, or a bit of both.
There are, of course, various other modern redesigns of the traditional flattop structure. I have four of them in my little stable of seven: the Mineur uses falcate bracing, while the Thunderhawk moves the soundhole off to the top of the upper bout, a place where structural strength is not required and where the soundboard is not doing much acoustic work anyway. Both Cole Clarks use a carved top with braces in the usual places but very light, almost token ones. All three different approaches work: those are four lovely guitars. On the other hand, my Guild and the two Matons are traditionally braced, and they are very fine instruments too.
I've played and liked X-brace Taylors and V-brace Taylors and nearly bought one or two. Are they "quite bright" TheMadMick? Sure: that's the Taylor sound. X brace or V brace, maybe there is a small difference but they all sound like Taylors to me.
Your friend may be both intelligent and wise, but from the comments above, I'm not sure he's entirely objective.
[disclosure]
I have a Taylor guitar and have been very impressed with their customer service and brand support. It was actually my 2nd choice buy, after I'd bought my first choice buy.
They research, they invest, and they're not scared to experiment to evolve the practice of guitar building. It seems to be that it's reasoned evolution rather than some of the sales-chasing marketing-led "innovation" that some other brands aim at (hello big-G).
Fundamentally, probably two things at play here.
Firstly, our attraction (or not) to the perceived ethos and value of an individual brand. Do we choose to (or implicitly) believe in what they're doing, and accept the face value, or do we take a more sceptical and cynical perspective.
Secondly, guitar building is a balance of art and science. Physics and engineering typically deal with non-variable materials within scientific rules. Wood is a variable material, the properties of which vary through time as well.
He did give credit where it was due:
and
by no means am I saying that Taylor’s design is flawed, merely that their assumptions are unproven.
I can understand his criticisms regarding the neck / headstock joint (and Taylor have indeed gone back to the scarf joint). Also putting in an entirely proprietary electronics package (the latest of which is a lot like the K&K system) pretty much guarantees obsolescence of the electronics, even while the guitar remains 'current / relevant'. Then you have to send it back to Taylor to install the latest pickup system...
Also as @Tannin correctly pointed out - the improved intonation thing is just so obviously bulls**t.
All of which makes me a little sceptical.
I'm really taken in by their Grand Auditorium shape (the *14ce series), even though I know it's sort of a compromise between the *12 (ideal for finger style) and *10 and *16 (better for strumming).
Martin are a lot more variable in their quality control - but when Martin do get it right, the instruments are something truly special.
Being a bit nihilistic here obviously but I personally do not think V-bracing is a major step forwards. Just different.
Top marks to Taylor for experimenting though. More top marks to them for using sustainable wood too.
