There'll be other brands recommended but La Bella is what I used back in the day.
One source would be Strings Direct
watch out when you fit them, they are far slippier than normal strings, and will slide out of the normal twisted fitting and damage the soundboard - you need to do 2 or 3 times as many turns when you twist them around, and it's worth doing this at the machine head too.
https://www.nylonplucks.com/accessories/try-carbon-strings-on-your-classical-guitar/#:~:text=They are made of harder,longer sustain and overall clarity.
PS I like that website, will have fun reading the articles on there.
But, reading your last post I think you might be best off with the low tension strings.
If you look at D'Addario they do their strings by tension, eg low, mid, high.
The more tension the more volume you get.
I've recently come across Aquila strings, which seem to have a variety of options, some made of unusual materials (sugar trebles?). I've ordered a few, I've just put a set of Alabastro ones on. They seem pretty good, i will update once I've used them a bit longer.
For heavier built nylon string guitars (e.g. some crossovers) I tend to go for Savarez carbons to give that additional bite through the thicker top.
Products catalog | Savarez
I'm pretty sure that's how it works.
