Trading feedback | FS: Nothing right now
JM build | Pedalboard plans
You can either loop the wires around the pins before soldering, or if you're being very thorough you can solder them 'endways on' and slide some heatshrink tube down over the pins to make sure they stay secure. In practice, simply soldering them endways is adequate anyway, if your soldering is up to scratch.
Desoldering the existing switch from the PCB can be very difficult without damaging the board. You're often better to carefully destroy the switch in situ using clippers, pliers etc to break it down until the pins are the only things left and can be unsoldered and removed individually, which reduces heating of the board. It's time-consuming but usually better than having to replace the board or patch it up with extra wires after the traces have come off.
Did I say I hate 3PDTs yet?
In the Earthquaker Devices pedal it's nice to see a 3PDT wired more correctly than usual, for once. (Diagonal bypass link wire, not via both poles.)
I managed to desolder the PCB. I tried to keep the heating to a minimum, using braid to remove the old solder. That part was OK, but the wires were so fine that one of them snapped as I was moving the daughter board. Removing and replacing that turned out to be harder than replacing the switch itself - but happily it's all working now.
I'll try the "endways + heatshrink" approach on the EQD pedal.
I think you might have mentioned that at some point ...
