FS: Taylor GS Mini SKB Hardcase
SKB hardcase for Taylor GS Mini - a few scuffs on the outside, but excellent condition inside, with 2 keys.
£75 collected, or £90 posted.
GS Mini SOLD
Taylor GS Mini Mahogany for sale. This is a super guitar, and it's in fantastic condition. The hard case has a few scuffs but inside is also near-mint.
This is a lovely guitar - super easy to play, and looks amazing! It has the factory-spec Elixir 13-56 Phosphor Bronze strings (although this particular set are not the factory installed set!) Selling as I've upgraded to a Gibson J45.
Comes with the SKB 1SKB-GSM hard case which fits it perfectly, and the GS Mini plug-in pickup, connected to the rear strap button.
Comes with original case candy, owners manual, two keys (unused), original pickup box and strap button, AND the original unused soft case.
I'd prefer collection from Lincolnshire, LN13 postcode, or I can bring it to my work in Lincoln, LN2 1DY postcode. I'd rather not post simply because I don't have a lot of time to properly wrap it as would be required.
£475. £400
"Nobody is really researching robot jokes"
the top is a tad bigger across lower belt giving greater surface area.
the sound hole is standard size not reduced like many parlours
the top is lightened at the edges to increase vibration.
it is simply X braced
the pressed slight bowl back is rigid but vibrates adding harmonic interest and focuses the sound in a good way.
they are shorter scales and if you hands like Hams then maybe not for you but they are a playable 43mm at the nut and widen at the bridge so not uncomfortable.
As you can probably tell I love the GSMini and spent a good time pondering why they work so well and have sold close to half a million.
there are plenty of clones these days and I have played a few and although there are some better built in terms of being built from solid wood sides and backs in China all called travel guitars none sound or catch the imagination like the GS mini.
so somebody give this one a home it will serve you well.
I read an article that said taylor had built an all solid version as a test and that it didnt sound as good , cant remember where , ive played all the versions and the mahogany one is my fave .... glwts
