Post your dream 5-pedal board
willowillo Frets: 386
I have been playing around with the idea of covering as much ground as possible from as few pedals as possible. Below is my idea of what would work for me - what would work for you, your dream 5-pedal rig?
The only conditions are there needs to be some modulation and at least one time-based effect (delay, reverb etc). It has to be something you think you could reasonably gig with. You don't need a tuner if you can gig without one!
Mine:
1. TC Electronics Mini Polytune
2. Strymon Compadre - giving me a nice couple of compression options and a clean/dirty boost
3. JHS Sweet Tea - giving me an overdrive and a distortion. Both can be stacked in different orders and boosted by the Compadre.
4. Wampler Terraform - I own this, its a lovely pedal. Other brands' modulation multi-FX get more attention but this works for me - no secret menus, its all on the dials.
5. Source Audio Collider - delay and reverb, a lovely unit and in a small footprint. Both this and the Terraform can run in stereo through my FX loop also.
So, this works for me. I think it covers a lot of ground whilst also remaining relatively simple. For example, I've picked the Terraform over other more complicated units because it is a bit more straightforward to use, with no submenus. For a similar reason I've picked the JHS Sweet Tea as a two-stage overdrive ahead of the Origin Revival Drive Custom, which is probably a better pedal overall, but I wanted to keep things at a level of relative simplicity that works for me.
«134
  • RaymondLinRaymondLin Frets: 11939
    edited April 2023
    I did this during the pandemic.
    I'll just use a clip on tuner...
  • markblackmarkblack Frets: 1591
    Chase Bliss Automtone.
    Flint.
    Chase Bliss Blooper.
    Zoia
    Ramble FX twin bender
  • benmurray85benmurray85 Frets: 1397
    Hudson Broadcast
    Kingtone Mini Fuzz
    MXR Timmy
    Ibanez Mini Analogue Delay
    JAM Harmonious Monk
    How very rock and roll
  • SupportactSupportact Frets: 1003
    I'd go for:
    Korg pitchblack tuner
    Boss SD-1
    Thorpyfx Warthog
    DOD Rubberneck
    Catalinbread talisman
    I use an AC15 so I'd use the tremolo on the amp. If I can't do that I'd need to swap the talisman for a trem.  I basically just need Tuner, dirt, tremolo, delay and reverb, so should be ok with just 5 pedals. Not that this stops me wanting more pedals mind...
  • chrisj1602chrisj1602 Frets: 4000
    TC Polytune
    Hudson Broadcast Dual
    Browne Protein
    Strymon Timeline
    Strymon Flint
  • munckeemunckee Frets: 12422
    My 5 pedal board currently is
    Keeley compresso
    SHO clone
    Thorpy Peacekeeper
    cheao joyo fuzz
    TC Ditto looper.
  • blobbblobb Frets: 3015
    Wahoo / '78 Distortion / Super Fuzz / Beebo / Trio+
    Feelin' Reelin' & Squeelin'
  • willowillo Frets: 386
    Love all these!
  • Fishboy7Fishboy7 Frets: 2227
    edited April 2023
    Not including the tuner its:
    Origin Cali76 Stacked Edition
    Hudson Broadcast AP
    Decibelics Golden Royale (Due in early May)
    Strymon Deco v2
    Surfy Bear Classic Reverb unit
  • tone1tone1 Frets: 5187
    My current 5 pedals are…
    1. Thorpyfx Boneyard
    2. Lazyj cruiser
    3. Palmer solid metal
    4. Lovepedal Les Lius
    5. Mojo Vibe
  • louis_LLMlouis_LLM Frets: 126
    Ernie Ball Volume Tuner
    Fairfield Barbershop
    Strymon Deco
    Keeley Eccos
    Strymon Flint
  • Paul_CPaul_C Frets: 7853
    Beebo
    Zoia
    Habit
    Mood
    Thermae (or a second Beebo/Zoia)
  • soma1975soma1975 Frets: 6828
    Miku
    Miku
    Miku
    Vertex boost
    Miku
    4reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • TheBigDipperTheBigDipper Frets: 4815
    edited April 2023
    God I'm boring....
    T-Rex Soulmate, containing (in signal order)
    - Moller overdrive
    - Mudhoney distortion
    - effects send/return (just returned a Terraform and a Mobius arrived yesterday)
    - Reptile delay
    - Room Mate reverb
    - clean boost
    and a "muting" tuner plus 10 presets for on/off combinations but not the pot settings - WYSIWYG.
    Last year I did all my gigs (rock/indy originals) with just the Soulmate. That band (someone else was the main writer/bandleader) didn't need any mod sounds. My current band does, so...
  • chromatunachromatuna Frets: 374
    I am working towards a five pedal board myself…
    Korg Pitch Black - the original one with Cornish buffer from FuzzDog added
    Mad Prof Forest Green OR Lovepedal OD11 - depending on what’s needed
    Bluesbreaker - Fuzzdog build
    Swamp Vibe - Swamp Thang trem and Magnavibe in one pedal - kit builds
    MXR Carbon Copy
    Nuthin’ fancy but works for me
    This is the truth from hillbilly guitars!
  • GavRichListGavRichList Frets: 7216
    If I’m ignoring the need for a tuner which a lot of you have, then:
    1. Origin Cali76 CD Compressor
    2. ZVEX Box of Rock
    3. Digitech Whammy 5
    4. Moog MF104M
    5. Meris Mercury7
    I’d also want a midi controller and a looper tbh. Fuck it, I’ll stick to a more appropriately sized board  =)
  • english_bobenglish_bob Frets: 5175
    edited April 2023
    Probably cheating, but what the hell. I'll cut down my current pedalboard.
    Boss ES-5
    Elektron Analog Drive
    Line 6 M5
    Sonuus Voluum
    Boss DD-500
    Dirt and delay is the bread and butter. The M5 can cover modulation, reverbs, pitch shifting etc. The Voluum does compression, tremolo and various volume-related stuff, but also transmits MIDI CC data for use as an expression pedal. I'll use the extra loop on the ES-5 for 4CM connection to my amp.
    Oh, and both the M5 and the Voluum have built in tuners. I'll see which one I like better.
  • GassageGassage Frets: 30951
    ThorpyFX Fat Gen
    Cornish G2
    Cornish CC1
    Boss CE1
    Cornish TES.
    Hudson Broadcast AP
    Strymon Deco v2
    Love this but I'm not sure you have space for the jacks in and out of the Cali  ;)
  • 26.226.2 Frets: 531
    Currently my 5 ‘core’ pedals are:
    1) Duke of Tone
    2) Barber Gain Changer
    3) DMM
    4) El Capistan
    5) Boss RV6
    Tremolo from the amp. There’s also a tuner on my board and 2 free slots for adding whatever I feel like - another drive, or fuzz or phaser.
