Maestro Singa (Mad RW / Adi Spruce), Taylor 512e 12 Fret Mahogany, DRL CT09 Thinline Acoustic
jaymenonjaymenon Frets: 815
edited October 2023 in Acoustics £
(Further pictures at the end of the listing)
Maestro Singa £2000
Medium Jumbo
Madagascar Rosewood Back & SIdes
Adirondack Spruce Top
Forearm Bevel
Sound Port
Florentine Cutaway
Ebony fingerboard
Gotoh 510 Tuners
Hiscox Hard Case
https://i.imgur.com/rIrjQlI.jpeg
Taylor 512e 12 Fret All Mahogany £1600
 Special Edition 512e All Mahogany 12 Fret (the all mahogany model was subsequently renamed the 522e, 512e is currently a cedar / mahogany job).
In beautiful condition.
The pictures tell pretty much the whole story…
1-3/4” nut
Rolled fingerboard edges
Tortoiseshell binding
Ebony fingerboard
https://i.imgur.com/88hrInm.jpeg
DRL CT09 thinline acoustic LR Baggs Anthem with 9v DC Phantom Power £750
https://i.imgur.com/0A1dXru.jpg
For sale is my DRL CT09 electro acoustic guitar with a phantom power system - powered by a TRS cable
Pretty much unused immaculate / beautiful condition.
Cutaway thinline electro-acoustic - braced like a conventional acoustic guitar
No sound hole - so very, very feedback resistant
Body: Hollow chambered solid mahogany
Top: Solid European spruce top
Neck: Mahogany
Contoured / Chamfered Heel
Fingerboard: Ebony with Abalone inlays
Gotoh 510 tuners with Ebony Buttons
No fret wear
Contoured heel
Strap lock system on the output jack
On board electronics upgraded to an LR Baggs Anthem dual-source system which involves:
1. Undersaddle 'Element' transducer
2. Bridge Plate mounted internal 'Tru-Mic' microphone
...with the ability to mix variable levels and blend between the two sources.
This goes beautifully with a LR Baggs Venue DI Preamp ( which I plan to list shortly)
'Phantom Power' supplied via a TRS cable which carries
1. Audio output from the guitar (to an amp/PA system) and
2. 9 volts DC to the guitar from an external power supply unit (included)
... so you never run out of power the middle of a gig.
Original Hard Case
In-line 9 V DC Phantom power system. Power reaches the guitar through a TRS cable. You can use any conventional 9 V supply or also included is a battery pack that takes six AA batteries, with a ridiculously long battery life - 42 times as long as a 9V pp3 battery (21ah, as compared 0.55ah with a 9v pp3 battery).  No ground loops, hum, noise 9v and lasts almost forever. And you can daisy chain that without any problems
Most acoustic guitar pickup systems sound lovely when playing softly. Start digging in and the horrible piezo quack comes in. Below is my demo of this guitar with the LR Baggs Anthem pickup system with intentionally heavy strumming, so as to reveal any weakness of the system.
First audio section involves just the UST undersaddle transducer
Second audio section incorporates the Anthem bridge plate mic.
https://on.soundcloud.com/ZQPJa8cbjk4Xetu57
Pictures:
Maestro Singa
https://i.imgur.com/12ZCvHE.jpeg
https://i.imgur.com/r8q6jWg.jpeg
https://i.imgur.com/OeZQP6r.jpeg
https://i.imgur.com/sj6sEpc.jpeg
https://i.imgur.com/wCYbvim.jpeg
https://i.imgur.com/lLoWVBN.jpeg
https://i.imgur.com/RGUOTYc.jpeg
https://i.imgur.com/Us10VmZ.jpeg
Taylor 512e 12 Fret All Mahogany £1800
https://i.imgur.com/DPXed9V.jpeg
https://i.imgur.com/SVMXk0t.jpeg
https://i.imgur.com/lSqRH66.jpeg
https://i.imgur.com/tyZYu39.jpeg
https://i.imgur.com/I3pZKj8.jpeg
https://i.imgur.com/MdQWyae.jpeg
https://i.imgur.com/iXhO11J.jpeg
https://i.imgur.com/4HlY8Oa.jpeg
https://i.imgur.com/h8SMxrF.jpeg
https://i.imgur.com/tDglMa6.jpeg
https://i.imgur.com/MIUJSOD.jpeg
https://i.imgur.com/WHD1bZC.jpeg
https://i.imgur.com/TKmFoeu.jpeg
https://i.imgur.com/AAf2eQo.jpeg
DRL CT09
https://i.imgur.com/fQLT2yA.jpg
https://i.imgur.com/ztzDOk5.jpg
https://i.imgur.com/ZWgrbeJ.jpg
https://i.imgur.com/EHOQks7.jpg
https://i.imgur.com/GEn3lSb.jpg
https://i.imgur.com/u3Py2ES.jpg
https://i.imgur.com/Q5rn80y.jpg
https://i.imgur.com/pHw9KdM.jpg
https://i.imgur.com/KG6C2Nx.jpg
https://i.imgur.com/FafB2YR.jpg
