I’m after a small, preferably cheap simple audio interface to pair with a Mac Airbook M2 for use as a portable recording option. It’ll mainly be to record acoustic guitar with a single condenser mic so one XLR input with phantom power is the only requirement.
Scarlett Solo would seem an obvious option (I already use a Scarlett 18i20 with my main DAW) but any views/opinions on others would be good.
I see there’s a very cheap M-Audio one but no idea about its quality.
I don’t mind buying used.
It can also be powered directly from a USB C equipped iPad.
If you are limited to USB-C, I think the new generation Focusrite Scarlett range all use USB-C and are pretty much the universal recommendation.
https://youtu.be/t2VnP-RfwqY?feature=shared
Si
