Simple Audio Interface?
AlbertCAlbertC Frets: 937
edited December 2023 in Studio & Recording
I’m after a small, preferably cheap simple audio interface to pair with a Mac Airbook M2 for use as a portable recording option. It’ll mainly be to record acoustic guitar with a single condenser mic so one XLR input with phantom power is the only requirement.
Scarlett Solo would seem an obvious option (I already use a Scarlett 18i20 with my main DAW) but any views/opinions on others would be good.
I see there’s a very cheap M-Audio one but no idea about its quality.
I don’t mind buying used.
  • droflufdrofluf Frets: 3750
    There’s a new version of the Scarlet Solo out so the old version (3) appears to be being sold cheaply.
  • fretmeisterfretmeister Frets: 24622
    Audient ID4Mk2 is very nice too.
    It can also be powered directly from a USB C equipped iPad.
  • AlbertCAlbertC Frets: 937
    Thanks, that does look a very good option
  • Do you already have a little USB-C to USB-A adapter or dongle/hub thing? If so, there are loads that fit the bill. Even the cheaper Behringer Uphoria stuff is fine, or a Focusrite Solo. I personally use a Native Instruments Komplete Audio 4, because it came with a bunch of extra software that I haven't actually used.
    If you are limited to USB-C, I think the new generation Focusrite Scarlett range all use USB-C and are pretty much the universal recommendation.
    Just so people are aware. I have no idea what any of these words mean.
  • duotoneduotone Frets: 995
    This is a good comparison video
    https://youtu.be/t2VnP-RfwqY?feature=shared
  • mrleon83mrleon83 Frets: 191
    I ‚downgraded‘ from an audient Id24 to an audient Evo 8 and have found no discernible difference, also really easy to use so would recommend :-)
  • SnapSnap Frets: 6265
    The Komplete Audio interfaces are great value and come with a good software bundle too. I have had the Komp Audi 6 MkII since it came out, no issues at all
  • monquixotemonquixote Frets: 17668
    I have the Arturia one and it's fine and quite inexpensive.
    It's also USB C
  • If you will cover postage I have a Mackie Onyx 2.2 you can have..
    Si
  • spir4Lspir4L Frets: 87
    I have the UA Volt 2, it comes with a good set of plugins as well.
