He’s also chosen to pick nearer to the bridge…probably for reasons of timbre…but the string does behave more at that point too (less deflection).
However, I think the main problem that the OP is describing is simply how the pick hits the string. As recommended above, some of the elementary CtC material talks about this with some nice visuals…might even be free access.
It's an Italian word and guitarists have effectively borrowed the technique from the mandolin. It is typically fast alt picking but there are different patterns so strictly speaking it isn't always uniform.
That might be what people often do (probably what I do) but it is meant to be within tempo. When Vivaldi wrote for mandolin I'm guessing he didn't put 'just go a bit nuts here' on the sheet music.
"However, if very short time values are used or if the tempo is very fast, all that may be intended is that the alternation of notes should be as quick as possible, i.e. not strictly counted. Careful composers add the word 'tremolo' (or 'trem.') when they want this effect.'
I'm quite happy to accept that they know more about it than I do but I think that tremolo can be and is played in tempo. The point of practicing it to a tempo is that you can play longer, more even passages.
Do not tremolo pick from the elbow. It should be from the wrist; start slowly until you can develop the technique.
Anchoring your palm to the bridge and body of the guitar can help with stability/picking angle.
Another tip would be to hold the pick nearer to the bottom so there's less material passing over the strings. That way, there's less of a counter force on the pick from the strings, and you're able to focus on a smaller area of the pick.
Also, since wading through a bunch of the CtC content, I stopped (lightly) anchoring to the body so much; favouring light contact from the base of the palm with the saddle area. I used to show the tinniest bit of pick too but that changed to facilitate downward escape picking (DSX)…so I show more but, hopefully, the contact area is still minimal.
Still a work in progress
This is the thing I'm always trying to emulate, just so clean and accurate there's no overdrive or distortion necessary
At best; probably not good to point out a particular method to a beginner that would cause issues a year down the line.
Base to bridge is how I would approach it personally. The angle it puts on the hand naturally lends itself to incorporating the thumb into the motion once you become a little more proficient.
Anchoring the palm can help when starting out, because it limits degrees of freedom so you're only able to focus on the correct picking motion as well as clarity. That way, once you have the technique, you can move further up the string for better note definition, and use your little finger on the high e to stabilise the hand.
I've found the added control helps with individually tremolo picking multiple strings.
To OP: Just start slowly and treat it as if if were any other kind of physical exercise. Once you have the technique the speed will follow.
Also, the 'start slowly' thing...I think it's valid for getting your head around something...but picking motion can change when ramping up the speed (cue the 'you don't learn to run by walking' analogy) so there's a lot of merit in 'starting with speed' (once you know what you're doing).
Disclaimer: I think these concepts are slightly beyond 'beginner' level.
