Jeepers, things have moved on in a short space of time, haven't they?
I love my valve amps, but I'm wondering about a purely modelling board with a PA cab now as something that is good and giggable/rehearsable.
It always seemed to me that you'd just buy one of the big, all in one units, like Headrush, or Line6, or Neural. But it seems we're now at the point where you could stick a ToneX and a reasonable multiFX on a Pedaltrain board and you're away.
Is anyone doing it that way? It seems to fit the modular need, i.e. just swap out a pedal rather than be tied into a monolithic and expensive single unit.
Trading feedback: http://www.thefretboard.co.uk/discussion/72424/
I would suggest starting with a HX Stomp (normal or XL), then maybe throwing a few pedals in the loop for that.
https://thefretboard.co.uk/discussion/249726/fx-for-sale-amazing-pedals-that-will-make-your-guitar-tone-different-to-what-it-is-now#latest
...into a real cab. As an experience, it's orders of magnitude better than running into FRFR or through a PA. As far as I was concerned, that rig was functionally no different to using an amp. Using a Matrix or Barefaced guitar cab, it's as light as you like.
I too For small and Gig able a HX Stomp with a at least an Expression pedal so Wha and volumes can be used.
A 1x12 combo and a small board is not that different in size (weight maybe) to a loud powered speaker and a GT-1000 Core/HX stomp
I just haven't decided if I really want to sell it rather than keep it and I have no idea what to ask for it, so currently inertia is winning.
This is a huge rabbit hole you can go down and the net result could be a rig that will likely be just as big and complicated (and likely sound less satisfying) than a compact valve combo and pedalboard.
I haven't yet mentioned that your rig is going to sound hugely different depending on the PA it's plugged into. Through something nice, great. Through a pair of Peavey tops? Absolute garbage. Therefore it's nice to have something on stage that picks up a bit of the slack.
Plus! No latency in the analogue domain. As much as I didn’t want to admit it, I could definitely detect latency in the digital setup.
(Still going back to the Simplifier Mk II when the board is rebuilt, though).
