I have a an old gas powered soldering iron which is getting a bit tired.....no cables is useful.....but what soldering iron would you recommend?
For the most part this will be for guitar electronics - and I guess the most power I will need will be to heat the back of a pot sufficiently that I can solder an earth to it....without cooking it..... I recall that abrading it with sandpaper and using a flat tip for heat transfer was recommended.....but there's the play off between getting it good and hot quickly...and cooking it
Then occasionally I might need to replace a component on a circuit board so need to be more delicate.
There's cleaning your tips with brass wool to keep them clean.....and overdoing it and wearing the tip out but anyhow....
There are USB powered ones, gas ones, soldering stations that have a scale of 1 - 5 or whatever....and then ones with a digital print out.
I don't want to spend hundreds but I will consider spending a little on a setup that's gonna last and last....
Let me know your thoughts!
Cheers,
Andy
The idea of not soldering to pot bodies, impressed me & makes a lot of sense to me. Plus, you won't need a high powered soldering iron
Byt yes, don't solder to the backs of pots. There are easier, quicker, safer (for the pot) alternatives.
That oversize tip is a good heat reservoir and gets the job done nicely on pots
the silver solder is a god-send too ( bought from rapid electronics)
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
For most hobbyists it's just faffy and irksome and I'm trying to think of another suitably lovely word to use.
