Ebay mark7777_1
Soldering to the back of a pot is daft.
This is the 'modern' way of doing it, which you will sometimes find in active basses or other guitar designs that aren't stuck in the 1950s...
You need something like this - https://www.tme.eu/gb/details/keys7313/solder-terminals-pcb-mount/keystone/7313/
Or this - https://uk.farnell.com/ettinger/19-05-745/solder-eyelet-3x-angled-0-169/dp/2691424
They seem to be oddly hard to search for! But this should do it -
grounding lug terminal solder eyelet
https://www.homeoftone.co.uk/blogs/news/the-signature-series-ground-bug-deal?_pos=2&_sid=82e272cf2&_ss=r
Instagram
And showing tone cap grounding, no pot lugs were bent and soldered onto casings. ( different guitar Highway One Strat).
Would like to try the Ground Bug, but they seem sold out, if anyone has a sales link, please post.
I need to do waaaaaaaay better with my soldering ...
Oh and like the OP, I don’t like solder on pot cases… I avoid it wherever I can .
In that case there aren't any nearby switches under which to fit a lug like the Ettinger used by @Mike58 . The cavity loop suggested by @Sporky would be good in a Les Paul type, but IIUC wouldn't work on a JM due to everything being mounted on the scratch plate.
JM build | Pedalboard plans
Ground bugs are on their way soon… keep in touch with James home of tone
I used plastic bodied pots once.
