Eventually I've negotiated a sort of music room for myself with Mrs C. The double bed has gone out of bedroom 3 and been replaced with two single futons (which are ace) and all of a sudden I've got a great small space (14' 9" x 8'). I have to be carefull I don't over fill it as a few times a year it will have to be used as a bedroom but I can live with that. The sound in there is great to my ears, I'm very happy and quickly I've noticed an improvement in my practice.
I'd like to do some basic recording of myself to monitor/motivate my progress. I don't want to spend more than I need and I don't want to have more equipment than absolutely necessary bearing in mind it does have to quickly revert in to a bedroom at times.
What equipment would you recommend?
By the way 99% of the time I only play acoustic.
For recording: can you get a laptop/computer in there? If so a cheapish USB microphone and a free copy of Audacity.
Regarding Garageband, I don't have any Apple stuff unfortunately.
I bet your scared now:-)
Ebay mark7777_1
I’ve also got just the microphone from this kit: https://www.marantzpro.com/products/view/pod-pack-1 that I’d be prepared to let go
The Marantz pack looks great value at £29.99 almost too cheap but like you @drofluf I'm not looking to become a Grammy award winner!
I think Audacity is more of a sound editor than a DAW designed to support multi-track recording, so you'll have to decide when it'll be adequate for what you plan on doing.
My recommendation - because it's where I eventually started and it's worked fine for me - is something like this;
https://www.amazon.co.uk/PreSonus-AudioBox-USB-25th-Anniversary/dp/B08D8R6VFC/ref=sr_1_3?crid=3EI7N91PAGUMZ&keywords=presonus&qid=1703100815&sprefix=presonus%2Caps%2C134&sr=8-3&th=1
That gives you the interface and a bundled version of Studio One (which is a fully functional DAW).
However, if you want to record more than two tracks simultaneously (eg a stereo-mic'd acoustic plus vocals) that particular interface wouldn't be suitable as it only has two inputs. (You just record each track separately, ie stereo-mic'd acoustic track, then a vocal track, then perhaps a keys track, etc - I've never found the 2 inputs to be a practical constraint.)
If any of your acoustics have built-in pickup, you'd save yourself the trouble of sorting out mics, placement, etc, and be less prone to the acoustic properties of the room. If you need to manage the recorded sound, then there are plugins a-plenty that will help with that (and not very expensive) once you've captured the recording into the DAW.
There are a number of Fretboarders that have studios or treated recording spaces. One example is octatonic's topic Studio makeover. Look for the finished bare room on page 1 and the same room filled with acoustic treatment on page 2.
Here is a finished panel (with a whole lot more in the making):
You can start with one or more and continue from there. You can even leave it until you start to get irritated by the boxy, reverb-filled sound of your recordings and then come back here to work out where to start. Help is at hand when you are ready to ask.
Edit: I forgot to warn you that any acoustic treatment that contains egg boxes, foam or carpet will not be the most effective or the most cost-effective methods. Anyone suggesting them should be politely ignored.
I haven’t done much recording yet but so far I got a couple of mic stands, Scarlett 4i4 interface and a couple of mics (Rode Nt1 and Beyer M88TG, which I already had). That works really well for acoustic guitars & vocals. That runs into Logic on Macbook or GarageBand on iPad depending on how much effort I’m making!
That looks a great job @stickyfiddle
Thanks for the pointer @drofluf with regard to the Zoom H1n, this actually looks a great simple solution for me. I've just ordered one from DV247. They are at the time of writing selling these for £51 which seems fantastic value for money.
