XVEX Box of Rock. Any good.
markjmarkj Frets: 914
Any forum members had any experience?
Yes I know that there’s one for sale here on the forum but my limited small board only has got space for the vertical version.
Any comment’s positive or not welcome.
  • monquixotemonquixote Frets: 17630
    Yes!
  • punchesjudypunchesjudy Frets: 1025
    Brilliant pedal!
  • jellybellyjellybelly Frets: 755
    Lots of bass but very good. The Distortron is the cheaper version and has variable bass response. Sounds like a Timmy with some midrange balls, to my ears.
  • TTBZTTBZ Frets: 2901
    I've had the Distortron and it's a great MIAB for those early Marshall sounds. Not sure I'd want the BOR as it doesn't have the variable low end control which I found useful with humbuckers, even on lower settings it was still quite thick.
  • slackerslacker Frets: 2246
    I've got the double rock. Same thing but a lot more versatile. Bass switches plus a super hard on option. The pedal. Not me.
  • markjmarkj Frets: 914
    Sounds just what I’m looking for.
  • GavRichListGavRichList Frets: 7164
    BoR is a glorious, glorious pedal. The boost side is as equally great as the drive side. Don’t hesitate.
  • PetepassionPetepassion Frets: 854
    Brilliant pedal, one of the most authentic sounding drive pedals I’ve used
    ‘It is no measure of good health to be well adjusted to a profoundly sick society’
  • lustycourtierlustycourtier Frets: 3333
    A brilliant pedal. Second only to ZVEX super duper 2 in 1 or SHO.
    Isn’t the BOR’s boost side just an SHO?
    I'm going to ask for positive comments only in future. This has been a wonderfully affirming thread to check in on.
    Let us know how you get on @markj ; I don't think I've ever heard a bad review of this pedal, just some people who ultimately decided it wasn't for them. Worth a shot!
    The only thing I would say as a consideration is as others have mentioned if you don't need the boost the Distortron is the same, but cheaper and has a bass cut control (As the BoR is a very bassy pedal)
    edited January 9
    genuinely never found it bassy! but then I play plinky guitars, and the tone dial is pretty wide-reaching.
  • CleckoClecko Frets: 295
    I've found this quite amp dependent. On an old JMP 2203, I found mine a bit flubby and hard to rectify through the tome controls. On a Bluesbreaker I found it a glorious thing of wonder, which was a way better solution for good sounds and feel at home volumes than using an attenuator (as well as being less hassle and cheaper). Possibly a bit better suited to lower output/single coil guitars. Worth a try IMO.
    It's very dependent on what you are trying to do.
    When I was using it into a Fender amp with a strat it was fine. Into a dirty Marshall it got a big flabby without bass cut.
    It's really not that bad at all.
    Just ordered from Hotrox.
    I will be using it through a Handwired 5e3.
    sounds great with both my Twin and JTM45. You'll have a grand ol' time.
  • LebarqueLebarque Frets: 3876
    I've got a Distortron going spare here if anyone wants it. As others have said, it's the same sound as the BOR, but with control over the bass.
  • bbill335bbill335 Frets: 1379
    distortron is loads better than the BOR, which is overly bassy. and you can put any old boost you like after OR before it!
    I’m afraid the pedal was returned today, it just didn’t seem to suit my amp.
    Nice pedal but I can live with out it.
