For what it's worth, I found that adding a couple of delay pedals to the Stomp's loops made it a totally giggable setup - I had everything I needed in a single preset.
Does it have features that you must have that the tonex doesn't?
If not then I'd say no.
I have a tonex and it's changed my musical life.
Had to buy some decent captures but once I did it came to life.
It does the sound in my head perfectly. I can't imagine something that sounds better to my ears.
Best £280 (used) I've spent in a very long time.
which captures did you buy? I’m struggling with my Tonex to get a great clean sound. I already have the input trim set to -3.0. Playing mostly with normal vintage style humbuckers so nothing that’s hugely driving the input.
https://www.thefretboard.co.uk/discussion/57776/handsomerik/p1
The effects built in to the kemper look very handy though.
I suspect I'd struggle to hear the difference between amp captures from the same supplier between kemper and tonex so it will come down to effects built in being useful or not, size and editing ease.
I don't really use a sparkling clean sound.
I'm loving the marshall superbass set which gives me the cleans I like.
I also bought their matchless dc30 set and fender delux.
I was playing with the deluxe last night which was really nice but I still didn't find it as glassy clean as my old Twin but was still a lovely sound.
Took it to practice last night and I'm very impressed. Only used a couple of the factory presets, "Dark Clean" was my favourite, and have bought a couple of Amalgam & Tone Junkie packs to play with this weekend.
Had no problem being heard against keyboard, bass & acoustic guitars (me Vintera Tele Deluxe).
One thing that's always irked me about Line 6 modelling is a tinny/fizzy top end that is really hard to dial out, but none of that present with the Tonex captures.
The only captures I've bought are from Alamgam and I'm very impressed. Would be interested in your thoughts on those and also the Tone Junkie ones.
Love my ToneX. The only other brand I had was a Quad Cortex but the ToneX captures were far superior to the QC for me personally.
As an example I'd like a Princeton style clean amp, some kind of silly hi-gain (SLO, Rectifier etc) for the chug and a mid heavy Marshal for classic tones. a smattering or Orange and Laneys to round it off. I have a Plethora X3 and a couple of drive pedals so i'm ok for effects mostly. (sorry for the mini hijack)
also a powered Pa speaker is a FRFR speaker and often less money,
I have one of these that I bought as a stage monitor.
https://www.pmtonline.co.uk/hh-hpx108-active-moulded-speaker-300w
In the past I’ve owned some very respectable valve amps. This is all I need these days.
maybe if I a/b tested it against my old jcm800 or vibkoking id want my old back but played on its own it’s 100% good enough for me.
It’s a godsend at gig too. So little gear to take,
I had an axe-fx (first gen) and had to sell it because I did more playing with the unit than I did playing guitar.
Then tried many incarnations of the helix and got the same. Too many different ways to go after a similar sound.
Since having the tonex I'm not tweaking at all. I got lucky and loved the first captures that I bought.
I have 3 sounds set up which is all I use live. All the same capture but with different gain levels.
Then I have a few other sounds set up that don't do what I need for live but are fun to play around with at home.
It's still early days but I've had it a month now and zero desire to tweak anything. Just enjoying playing.
Shame you're not closer or you'd be very welcome to come and try it.
Option paralysis - how far do you go testing different variations on a theme (as with ir’s). Fat, thin, balanced, clean, edge, crunch, dimed, the list is almost endless which is why I just went with the balanced versions.
