If you remove 1.5mm from the edges, you'll either need to recarve the back of the neck, or you'll end up with an odd-feeling ridge there.
Likely that you'll also have to do some fretwork on the affected part of the neck.
You have to consider what happens where it goes across the body. Will it expose things you don't want to see? will you have a ridge in the cutaway, or reshape body to match?
it's not that uncommon to see old guitars converted to Tenors with the neck slimmed down in this way. often they leave the bit across the body full width
Instagram
It's not a cheap job (at least not with him) but they come back very good - but it is usually the entire thing - like turning a 42mm nut P bass neck into a 38mm J type - and adjusting it all the way to the heel.
I wish I was kidding, but I'm not! I can't find any pics now, so I suspect it's been re-necked and the evidence has been destroyed... (And the guitar no doubt sold as 'original'.)
i do remember that goldtop, here is a more recent conversion
https://www.gbase.com/gear/gibson-les-paul-studio-tenor-conversion-2001-black
Instagram
Prefer a raw, oil finish on a neck anyway. Slow as you go, and you'll get there.
Was pretty painless tbh. It's only a Harley Benton DC, so not like I was about to ruin a vintage guitar.
Feels a lot better now and plays just like a 50s Jr
