Long leg or short leg?
rlwrlw Frets: 4696
What is the difference  between long and short leg HB pickups?  I have a set where the legs measure 1/2" from the bottom edge of the body of the pickup which, I assume, are long leg.
Am I right?
  • OilCityPickupsOilCityPickups Frets: 10449
    Am I right?
    You are ... generally I say long legs for Gibsons ... short legs for everything else.
  • ICBMICBM Frets: 72361
    Long legs if there’s enough height for them, since they wobble less. Short if there isn’t.
  • guitars4youguitars4you Frets: 14266
    And I thought you wanted to know the difference in cricket fielding positions
  • elstoofelstoof Frets: 2481
    Foghorn Leghorn?
    Generally the tendency these days is for pickup routs to get shallower - Ibanez and PRS to name but two companies who are not allowing space for longer legs, or even full length pole screws ... and in the case of some newer Ibanez instruments, no crank at all is allowed for on the baseplate. With the correct length springs and proper fitting there should be no more 'wobble' in short leg pickups than in long ones. If you buy short leg pickups they will be usable on a wider range of instruments, plus it's actually very difficult to get 52mm spaced pickups in long leg.
  • FunkfingersFunkfingers Frets: 14434
    Ex-military servicemen will be relieved that the thread question was not about short arms.
  • Philly_QPhilly_Q Frets: 22874
    Am I right?
    Especially if it's something like an SG or Flying V with a scratchplate-mounted bridge pickup.  If you use a short-leg pickup in that situation the height adjustment springs may be squished to the point that they won't squish any more.
    Philly_Q said:
    Am I right?
    Absolutely ...
    Depending on the neck pitch angle, some SG and Flying Vee bridge pickups need to stick out a long way from the mounting surround. Short lugs will not reach. It takes long lugs and short springs.
    I think I said that.  In different words of course.  ;)
    Sorry. I left the Discussion to answer a PM about Charvel spare parts. Your comments were displaced from what is left of my short term memory.
    Probably for the best.  :)
