Generally the tendency these days is for pickup routs to get shallower - Ibanez and PRS to name but two companies who are not allowing space for longer legs, or even full length pole screws ... and in the case of some newer Ibanez instruments, no crank at all is allowed for on the baseplate. With the correct length springs and proper fitting there should be no more 'wobble' in short leg pickups than in long ones. If you buy short leg pickups they will be usable on a wider range of instruments, plus it's actually very difficult to get 52mm spaced pickups in long leg.
