My partner is having a a bifold door put on the back of her house (the wall got knocked out yesterday as part of some the work)
The builder has said that the fixed single door part of it will have a handle on the inside but not on the outside - so if you go out through that (with the door not in bifold mode - just using the regular door part) and it closes behind you, you can't get back in from outside.
Given that the front door is one that locks when you shut it - that sounds like a recipe for getting locked out a lot. Or for having to prop the back door open permanently when you're in the garden making the whole house cold.
Is this a thing?
Is it because the way a bifold folds there can't be a handle on the outside?
Red ones are better.
My sister & her other half run a window business and have been in the trade for 20-odd years; I'm happy to ask if useful! I can see from their website that they've fitted some with external handles and some without, so it certainly can be done
(*) Yes, it will also serve as a music room!
JM build | Pedalboard plans
Not having an external handle sounds daft - what if you want to go into the garden but not have the door left open?
Apparently it's what they put on next door's extension.
Thanks all for confirming I'm not going mad/asking for the impossible.
She's spoken to him and apparently it will be sorted. We shall see.
(The builder seems ace to be fair - he was reporting what his bloke he gets doors from said)
This info has not yet been shared.
Tune in to the evening news for further updates...
There's a separate low profile handle on one of the panels which is only interior, but that's not the main handle to open the door
If they are of a decent size I’d always recommend aluminium, as the movement in plastic would cause problems during winter and summer temperature changes.
Yep they're going to be aluminium.
I pretty much only do forum on my phone and spend 80% of my time editing badly typed sentences.
It should have read "been resolved"
My phone is weird - not only does it autocorrect away from correct spellings to non existent words it also deletes characters that were previously on screen. Or I'm senile and/or getting finger-Parkinsons.
I am now imagining that Benniro Esnoit was a 70s lounge singer.
