Hi guys - I've just acquired a Tele neck - official Allparts Fender-stamped replacement - with a pauferro fingerboard for a hopefully-fun Tele build I have in mind (basically a Hendrix Reverse Tele, with a reverse headstock and a reversed bridge pickup). It's my first pauferro 'board, but even I could tell it was dry as hell when it arrived - the neck profile etc is fine, it's just that the wood was practically dessicated-looking. I've given it 4 courses of lemon oil now and the colour is much better but it still seems kind of dry to me, so my query is - is pauferro just an innately drier wood, or should I keep going with repeated applications of lemon oil until it's closer to the rosewood 'boards I have?
TIA for advice
If it feels rough it might have some run out in the grain, so you get a bit more end grain under your fingers.
I'd be rubbing back with 0000 Liberton wire wool to smooth it out, then oiling and buffing again
Instagram
The Fender stuff is very low grade, but with a very light rub with very fine wire wool and lots of lemon, it’ll feel great.
And then more character etc.
Love a rosewood board, not quite so keen on maple. I am pretty sure that Pau Ferro has a smidge more snap than rosewood, so therefore is a nice companion.
I think it's a fine wood, but it does look a little odd on Fender guitars because it's, errr, ingrained that we're used to seeing them with darker rosewood boards.
Awesome....
Some pau ferro is dry and slightly rough (as rosewood can be) - nowt to do with the wood, it's all down to lack of finishing from the factory.
You can adjust the above to your desired level of smoothness. Works a treat for me.
https://cziltangbrone.bandcamp.com/album/null-hypothesis-5-ep
https://cziltangbrone.bandcamp.com/album/machine-space-2
It is a high grade hardwood that sits nicely between Indian rosewood and ebony in every measurable way except colour.
Some of Fenders stocks have been a little bit paler, but most i see for sale is a good mid brown rosewood colour. Price has always been comparable too, I used it on my first build over 20 years ago and could I've just as early got Indian for the same budget. The stacks were next to each other.
It is often to do with the wood, because even without any treatment some boards will feel rougher than others.
Boards with run out often feel a bit rougher than those without, especially if it's a wood with open pores
I once had 4 high grade ziracote boards, all from the same source. One was noticeably rougher than the others no matter what I did to it. The other 3 took a nearly mirror shine after my standard level and polish, but this one wouldn't. Guess which one had the most run out in the grain
Instagram
Montys do a better treatment.
I went into it with slight reservations of the unknown but I needn't have bothered. It's a lovely wood that looks rather like rosewood to me without the pores.
Feels nice under the fingers too.
Here's a pic as it came out of the box.
Nothing to moan about really is there?
