I prefer the slightly bigger amp (half way up on the volume dial of a 28 Watt Rambler is not obnoxious in terms of loudness) that's not being throttled so I can coax some big warm cleans and add overdrive and modulation sounds from pedals without the amp adding anything I haven't dialled-in myself, so my sound is consistent in various sized rooms.
I can hear everything clearly on stage without having all the amps mic'd up, amp stands help and I only listen to the drums and vocals half the time anyway...
With so many comparison web sites out there, how do I choose the best one?
I'm with @ICBM on this. My first valve amp was a Laney Cub Head (15w) - prior to that, I was using solid state amps - either a Roland Cube 60 or a Tech21 TM60 - both 60 watts. The band I'm in plays a variety of covers across a range of genres and I needed loud cleans as referenced as Sound 2 in ICBM's post above - " and on the other hand *strictly* clean (no clipping whatever), full barre chord rhythm, bandwidth-hungry effects, with deep bass" Either of the two solid state amps could deliver this easily and be heard over the non-miced acoustic drummer. The 15w Laney couldn't do it - just disappeared from the mix as soon as the band got into full swing. But that's on *strictly* clean sounds only. Overdriven volumes were not a problem and could easily be heard. I've since replaced the Laney with a 50w Vox Night Train and no problems doing the loud, clean thing with that. I'm just not that taken with the drive sounds....I've also recently picked up a 30w Orange Rocker head and although I am yet to try that at rehearsal, I am fairly confident it might hit the sweet spot....
As has been said, there are no rights or wrongs and a big eye opener for me was the relatively small volume difference between running the Laney on the <1w setting vs the full 15w. I think the volume generated by your drummer will have a significant impact on what amp you can get away with if you want to go un-miced.
(When we were young 'uns, we got my mate's JCM800 Zakk Wylde - 6550s and 120W, you'll recall - half stack and dragged it out into the garden and pointed it out over the open fields behind and turned it up to 10. We took it in turns playing while the other wandered round in the field. At about 30-40m, off axis was very quiet. But when you walked into the beam, which happened fairly suddenly, it was like someone had put a pair of really loud, tinny JCM800 headphones on your head. So, for a small outdoor crowd, without PA support a JCM800 sounds either inaudible or shit depending on where you're standing.)
Bandcamp
Spotify, Apple et al
