MaxRossell's Nitro Tele Refinish. Pics!
Tex MexicoTex Mexico Frets: 1198
edited July 2015 in Making & Modding
I just got another AVRI tele and I've decided to refinish it.
It's this one:
Anyway, I want this process to be as painless as possible, so I don't want to take it down to the bare wood. I'm thinking of sanding it back enough to take most of the colour coat off (it's Fender's "flashcoat", whatever that means, over white primer), then just respray it shoreline gold and give it a topcoat. I'd use Rothko & Frost cellulose rattlecans.
Any reason I shouldn't do it?
«134
  • TTonyTTony Frets: 27732
    I'd ask @RothkoAndFrost for their opinion.
  • martmart Frets: 5205
    Meanwhile, somebody will probably come along and say you can't do it because the Tele looks great as it is, and that a Tele in shoreline gold would be an abomination. :)
    4reaction image LOL 0reaction image Wow! 1reaction image Wisdom
    The Tele looks great as it is and a Tele in shoreline gold would be an abomination.
    6reaction image LOL 0reaction image Wow! 6reaction image Wisdom
  • timhuliotimhulio Frets: 1286
    Why ruin the existing finish? Can't you buy a fresh Tele body from GuitarBuild and swap bodies? Then you'd have a blank canvas and wouldn't have to strip or sand this one.
  • GagarynGagaryn Frets: 1553
    If I was refinishing that in gold, I'd go for a gold sparkle like Dick Dale's start. That would be immense!
  • topomortotopomorto Frets: 68
    Just buy a bunch of glitter pens and get a few neighbourhood six-year-olds in...
  • impmannimpmann Frets: 12685
    Tbh, refinishing it will kill the resale value. A home refinish rarely looks as good as a factory one (there are exceptions, I accept) and I think you may ruin the guitar. Plus as ICBM has rightly said on a couple of occasions, changing the finish can affect the sound...
    It's not often Mr Hulio and I agree but I'd say his idea is best. That way if you don't like it or it gets ballsed up, you can put it back as it was.
  • SteveRobinsonSteveRobinson Frets: 7088
    I'm not familiar with "Flashcoat" but if it's anything like earlier AVRIs then there is a polyester sealer coat under the lacquer. You can strip the nitro down to the sealer using cellulose thinners which won't touch the sealer. The sealer then makes a nice flat base for the lacquer.
    Test first in a cavity!
  • Tex MexicoTex Mexico Frets: 1198
    *sigh*
    How about we assume I'm aware that the resale value won't be the same and I don't care, I'm not interested in spending hundreds more on a whole other body to end up with a completely different guitar just to have an LPB body sitting around doing f**k all, and that I'm not some complete bell-end who will inevitably balls-up anything I attempt with a rattle can, and instead approach this from a perspective of I know how to refinish guitars, I don't like LPB but I like shoreline gold, and I'm looking for reasons why I would encounter technical problems with this combination of paints?
    You know, one of the reasons I don't go on guitar forums as much as I used to is that you ask a simple question that should have a ten-word answer and instead you get a dozen guys telling you you're incompetent and your taste sucks and your idea is stupid and the only way to get right is to spend ten times more money doing something completely different.
    1. I'm going to refinish this guitar, in a colour of my choice.
    2. I don't give a shit how it affects the resale value.
    3. I won't screw it up because I know what I'm doing, but if I did it would be my problem.
    4. I'm asking if a specific type of paint requires more preparation than I currently plan to do.
    Now does anyone have anything helpful to add to that, or do y'all want to keep telling me that the most important thing is what happens if I decide to sell it?
    5reaction image LOL 4reaction image Wow! 2reaction image Wisdom
    Thank you Steve! Exactly the the kind of info I was after.
    By the way, do you do also shoreline gold in rattlecans?
    I had a sparkle gold tele not long ago, one of the 72 Deluxe FSRs, and it was nice but a bit too blingy for me.
    I certainly do.
    I can probably sort out a forum discount too.
    Oooh, that's cool.
    Question: for lacquer thinner, what do you recommend? I have some nitromors (recent) lying around and can get hold of acetone pretty easily, would either of those do? I've only ever stripped urethane before so not sure.
  • jd0272jd0272 Frets: 3867
    I used acetone for nitro.
    Do you know if acetone would have an effect on the poly base coat they put on these guitars?
    Couldn't say Max.
    edited July 2015
    Tex Mexico;717401" said:
    *sigh*
    Ok fella.
    Only trying help.
    Not being funny but if you "know what you are doing" then why ask in the first place? Especially in view of the question you asked at the end of your initial posting... How are we to know you are an expert?
    Good luck with it.
    Acetone is a major component of lacquer thinners and will do the job. It's probably a bit cleaner to use than Nitromors and neither will affect a polyester sealer.
    But do check in a cavity first! :)
    Nice one Steve. I'll be in touch about the paints.
