Neck Plates vs Screws and Washers
The things I really don't like about Telecasters is that big square neck joint with a metal plate on top.  It makes upper fret access really cumbersome.  What are the pros and cons of using inset screws and washers like Jaden did on digitalscream 's beauty?
  • TTonyTTony Frets: 27650
    Not the best photo - it wasn't taken to show off the neck join.
    One of the big pluses (for me) of avoiding the neck plate is that you can also carve away the treble side of the heel.  Which feels much nicer when playing up that end.
  • John_AJohn_A Frets: 3775
    ^ what guitar is that?
    ^^ this one @John_A
    (A self-build from a couple of years ago).
  • paulnb57paulnb57 Frets: 3057
    Can't see an issue, 6 and two 3's I reckon.......
    @TTony that's lovely, nice work !
    I find neck plates a bit cumbersome. Might be imagined, more than anything.. The ones I've put together then to have screws and washers. As said, before, you can shave and shape the body for comfort and access, if you don't have a neck plate.
  • impmannimpmann Frets: 12669
    You can always recess a neckplate - five minutes with a router...
  • WezVWezV Frets: 16746
    only thing to be aware of with ferrules is the body thickness.   If you are going for better acess its not uncommon to see the heel thinned down too, and then you  get into neck heel crack territory.   although you can generally loose a bit of thickness and still be fine
  • RolandRoland Frets: 8743
    That's 4 minutes and 50 seconds clamping and checking, and 10 seconds routing and dusting!
    Having looked at the pictures on Jaden's website I'm going to ditch the neck plate on my next build
  • SimonRFSimonRF Frets: 127
    Love these recessed washers and neck plates, have set them up today to be an option on our bodies.
    @TTony - lush!
    Rothko and Frost | R&F Facebook | Luthier Club | Nitro Aerosols | Decals | Paisley
    Nitro lacquers, decals, inlays, bodies, wood - specialist materials and custom machining for luthiers and instrument makers.
  • RockerRocker Frets: 4989
    Tom Anderson neck plates don't get in the way. Look at one and see how it should be done. @TTony did a great job on that red Tele build.
    Nil Satis Nisi Optimum
