contactemea@fender.com
They are great so far
Really compact light but well made
https://m.thomann.de/gb/km_17515_guardian_transluzent.htm?ref=mpd_ra_2
Any finish could be stained if a dye isn't stabilised or becomes unstable over time. But the attack that nitro can suffer from foam/rubber is a different thing.
Nitro can be attacked, damaged; it's a fragile finish which dries by solvent evaporation. Actual poly (polyurethane) could be affected, which was used for a while and is also a single-component paint.
2-pack which is also called poly (wrongly, and only in the guitar world) is a different animal, it sets by catalytic reaction with an activator. This is very stable - it's on your cars, which remain in contact with all sorts of rubber, foam rubber etc, for years without being affected in the slightest. It can be stained by dye leeching but usually it would be poss to cut & buff that out. Although red dye on white for instance is hard work to get totally gone. White takes no prisoners.
