Double sided tape
I used to use B&Q's smooth carpet tape for temporary fixes and for sticking router patterns to wood etc. but they don't sell it any more.
I'm using some stuff from ScrewFix at the moment, but it's a bit thicker and has some "give" to it so router patterns have a chance of moving slightly if I'm a bit heavy-handed so if anyone knows of a thin, smooth double-sided tape to replace the B&Q stuff I'd be grateful.
The other option is to order loads of different tapes from Amazon/Ebay/etc. and that might prove expensive and still not get me what I want.
Any suggestions?
  • Adam_MDAdam_MD Frets: 3420
    Maplin do one but as its Maplin it won't be cheap.
  • ecc83ecc83 Frets: 1639
    Hobbycraft?
    Dave.
  • octatonicoctatonic Frets: 33826
    edited October 2015
    I used to get mine from Atlantis in Shoreditch.
    It is an art supplies shop- really good quality so I bought loads.
    I have enough for the next few years probably.
  • steamabacussteamabacus Frets: 1268
    edited October 2015
    Have you come across the 'masking tape trick' as described below? It may be a better solution for you than double sided tape?
    https://www.youtube.com/watch?v=_Fiwc5yGHn4
  • TTonyTTony Frets: 27657
  • NickLNickL Frets: 153
    B&Q still do a smooth carpet tape which may be the same stuff, or at least they did last weekend when I bought some - it's branded as "Diall".
  • Paul_CPaul_C Frets: 7828
    they didn't in the Northampton branch last time I was there, I'll go and have a look.
  • SargeSarge Frets: 2429
    Wis awarded!
    Bloody Nora! what a great trick, me likey!
    edited October 2015
    He calls himself a 'master lutheir'.
    Is anyone truly a master of anything they cannot spell?
  • FelineGuitarsFelineGuitars Frets: 11619
    edited October 2015 tFB Trader
    Sellotape double sided used to be good until about 15 years ago as it had a vinyl carrier.
    They switched to a paper carrier and the tape became useless for this purpose as it disintegrates as you remove it and clean up is a bitch.
    However Scapa tape took over the old style tape, but it isn't easy to find.
    We get it in bulk cut to size from Parafix tapes and tare thankful as it's been the best we've found
  • SassafrasSassafras Frets: 30301
    Yes, that sellotape one is an absolute pig to remove. It actually sticks 'too' well.
  • GuitarMonkeyGuitarMonkey Frets: 1883
    edited October 2015
    It always seems to stick better to its backing paper than anything else.
    Sod the spelling, he passes on awesome tips.
    Have used the tape and CA method extensively recently and it is superb.
    Also have quite a few of his tools which are also excellent.
  • ICBMICBM Frets: 72544
    That Crimson Guitars guy is Bill Bailey. When he's Bill he has the wig covering the tattoos.
  • GSPBASSESGSPBASSES Frets: 2351
    The link below shows the type I use. I've been using it now for about 15 years is never let me down it is  a high quality professional type, can't go wrong with this one I've never had slippage or a jig move while I've been routing.
  • speshul91speshul91 Frets: 1397
    Wickes. 3 quid and grips anything.
