I've got a 2x12 cab laying about which I intend to load up and get using with my Super Sonic 60 head. At the moment it's only got a G12H30 in, which isn't any good on the power front.
I mainly need the amp for it's cleans, and I'm thinking I want something pretty high powered in the cab. So, grateful for your recommendations.
Trying to avoid V30s as I had a couple of those before and were rather muddy on the clean side of thingss, for this amp at least.
Don't know what the drive units are but Fender's own S-S 60 2x12 cab is only rated at 60watts, so it does not seem that you need power monsters in there?
Budget? The Creambacks seem well liked at £99 a pop.
Dave.
Yes, I've read some good things about the creambacks.
Interesting on the Fender cab, this used to come with 2 V30s, so 120watts. Maybe they've changed it.
"Gordon's Alive?!?"
Cheers all, in the absence of Brian Blessed the 75 watt Creamback is a good shout, and 2 even more so.
EV.
I have an EV and an Emi Red Fang Alnico in an oversize 2x12 and it sounds great. It just gets better the louder it gets. The RF never gets strident like a Gold, and the EV is just so solid and well, muscular..Clean its very good indeed but hit it with some dirt and wow!
I used to use a v30/g12h mix in my zilla. I swopped the 12 for a 75 creamback to better match power, and I can't tell the difference I the mix.
I still have the g12h30. It's a 16 ohm but available if suitable and relatively close (I'm nottingham).
