Firstly, apologies as this is my first post and quite long as well as asking for advice. Hopefully will be able to contribute more in future!
I've decided it's time to get a more suitable amp after being stuck with a Vox modelling amp and a Marshall Valvestate stack, neither of which are what I want for tone/practicality reasons.
The amp will only be used at home and due to my family situation will more often than not be used via headphones - so an emulated output is a massive plus point.
I generally play a lot of rock/metal and have a decent number of pedals, so the onboard distortion isn't essential but I would still like something useable.
This lead me to a choice between the HT-5R or a DSL5C.
However, after doing a bit of research the HT-20/40 sound far more appealing in terms of sound and options but don't have a dedicated headphone out.
This lengthy pre-amble leads to me two questions.
1) What kind of headphone amp/mixer would I require to run from the emulated out and is there any point? Ie. Would I lose the emulated benefits by running it though an amp/mixer?
2) Should I just suck it up and get one of the 5 watters (or any other recommendations people may have)?
Will have a look at the Yamaha's though - cheers.
Someone I know has one of the Blackstar ones and really rates it:
https://www.blackstaramps.com/ranges/idcore-beam
Not really looked at headphones yet - while I'm leeching advice any on decent headphones would be much appreciated.
Liking the look of the Yamahas - think I may end up with 2 new amps!
The HT-20 with a headphone amp or mixer (or AI, is computer recording on the cards?) would be the more flexible option from the HT-5.
Running the EM out through a mixer etc will not change the voicing (tho' a mixer will have EQ if you want it)
The 20 also has the option of running just as a pre amp, pulling out the speaker jack turns off the output valves so whilst you are using cans (90% of the time?) you are "saving" the EL34s and few pennies, around 35W, on the lekky bill!
I cannot of course comment on the other amplifiers mentioned.
Dave.
Question ICBM et al. Which amplifier manufacturer was the first to fit an emulated output on anything? Amp or pedal?
I have known of "guitar amps" for nigh on 60 years but only found out about "emulation" some 10 or so years ago.
Dave/.
Just thought Gruff'! You COULD save a lot of dosh by just buying a Dual HT pedal and the HP amp!
Got the valve, the volts AND the EM output!
Dave.
soundcloud.com/thecolourbox-1
Hmm, so it COULD have been originated by the Marshall then Blackstar designers? Obviously not patentable or else someone got a severe bollocking!
Dave.
IMHO if you could stretch to a second hand Laney IRT Studio and a cheap cab, you'd probably be very happy with it.
