Trace Elliot Spares?
martinwmartinw Frets: 2149
in Amps tFB Trader
Anyone know where I might be able to get a new mains transformer for a Trace Elliot AH-500 12 bass amp?
  • rossyamaharossyamaha Frets: 2462
    Pretty sure you'll only get one from the US now. No one took on the distribution or service when Peavey closed. I think Peavey US will supply you though.
    Well worth asking these guys - http://www.electronicmusicservices.co.uk/ - I was pointed at them by Peavey when I had a query with my Trace TA50R.
    edited April 2016
    Weird double post.
  • jpfampsjpfamps Frets: 2734
    I'd be surprised if there isn't an Ashdown unit that would do the job.
  • DJH83004DJH83004 Frets: 196
    This guy, Chris Goodwin is International Customer Service Manager, has been very helpful in the past
    From: customerservice@traceelliot.com [mailto:customerservice@traceelliot.com]
    Sent: Wednesday, March 2, 2016 8:33 PM
    To: Dave Hunter
    Subject: RE: Trace Eliott TE 715X
    Chris Goodwin
    Trace Elliot International Customer Service Manager
    -------- Original Message --------
  • ICBMICBM Frets: 72574
    Is it a Toroid Audio P/N TI-053010B, Peavey PTE-TX002?
    If so I have one spare.
  • martinwmartinw Frets: 2149
    It's not a Peavey-ownership amp, it's a 99 model, pre all that.
     I wonder if it would be the same though. If so, I'm very interested.
    I'll have a look for a part number shortly. I do remember it's made by Demeter Windings.
    Thanks for the other pointers too. :)
    There's a chap I work for who has a shed full of old Trace gear, I'm pretty sure there's at least one dead older AH500 in there - not sure of the age, but between this and that it's possible there will be something that fits - I'll ask him.
    edited April 2016 tFB Trader
    That would be great. I'm happy to pay a decent price as my customer wants his amp back again!
    Here's a pic of the offending article:
    Part No appears to be 72-TRAN-500-1299
    It has 5 secondaries.
  • exocetexocet Frets: 1963
    Demeter Windings are still in business? Located in Chelmsford Essex.
    Bugger… I'm almost certain all the old dead ones are blocks not toroids, but I can find out for sure in a few days.
    This one doesn't look quite right either - four secondaries:
    275V
    85V no centre tap
    16V-0-16V
    16V-0-16V
    (Approx, measured with 24V on the primary.)
    I've also got one out of a Warwick, but it looks like it might be too large a diameter to fit in that amp even if the secondaries were right, and I think the amp was only a 300-watter.
    May be best to contact Demeter, although if they have to wind something that's out of production it might not be cheap.
  • crunchmancrunchman Frets: 11469
    We had a Gallien-Krueger bass amp in church that had a toroidal power transformer go.  The repair place we use said they couldn't get a replacement.  We ended up getting another amp.  Why can't they use something off the shelf?
    You often can, or use a transformer from another manufacturer.
    The cynical view might be that the repair shop had enough work on that they didn't want to go to the effort of trying to find a replacement.
    Getting a unit custom wound isn't that expensive either.
    I'm going to make some calls today. If I can't find one in stock I shall be getting a custom wound unit made.
    I very much doubt Demeter hold any stock, but they might have spec available.
    I know the problem. It can sometimes be tricky to get a replacement that matches all of the combinations of secondary voltages in a multi-winding transformer, and which physically fits as well - although that's usually easier with toroids.
    It's why I keep the transformers from anything I've scrapped - unless I've got multiples (eg Marshall DFX…) - even though they're actually one of the less likely parts to fail in a modern amp.
    If Demeter have no stock it's also possible they have no new formers either, but rewinding the burnt out original should be a possibility.
    That particular amp was only around £300 new, so it probably wasn't worth going to too much expense on.
    Well I phoned Demeter Windings, and they are making a new transformer for the amp. The price is very reasonable, so all's well that ends well.
  • 4114Effects4114Effects Frets: 3131
    Complete and utter necro thread bump, but I have a trace 1210 with a blown power tx, can you pop me a message @martinw and let me know if/ how I can obtain one :-)
    @ICBM still have one spare? Lol
