We could fall out here.....
Can't vouch for the Thorpy as I haven't had the pleasure of trying one yet, however I do own the Xotic SL and it is superb!
I just didn't see how the use of large format through-hole components had to do with noise floor and consistency. The latter two are surely more to do with good design and choosing the right composition of components. Also through-hole is more widely repairable by guitar/amp techs I would think (tying into your mention of longevity and robustness).
I just wasn't very clear. the two choices are mutually exclusive. Size is because i want to build them (and repairability) and the specs were a separate consideration.
I liked the bigger components because it meant I could route PCB tracks underneath them more easily - I've hand-soldered the bigger SMD stuff without too much bother. Some of them I can barely see unaided though.
I have a suspicion I was using the same polarity protection scheme as you.
It's tiny. Well tiny compared to some of my muses past and present it is.
Re the tones- the only thing I've across that's tonally similar is a KOT which is two channels but the GS works like that with its Caliber and Gain stacks. But it's not as thick as the GS.
Would love to have a look inside one (as well as play one!)
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
