My other setup is a deluxe reverb as a clean platform, using two low gain and a higher gain overdrive selection for different drive flavours. (klone, fulldrive 2 TS mode, sl drive)
PA Hire and Event Management
Peavey Studio Pro 112
Feedback
Avoid a fargen townhouse 20. Piece of junk.
However... I've heard some incredible sounding rigs using a blackface or silverface fender and a board, with all distortion coming from Rats and stuff. So its doable for sure.
My favourite is my Dr Z EZG. It will produce sublime harmonics, sag and distortion when pushed with a clean boost, but hit it with a nasty distortion and it will hold up remarkably well, even in drop tuning. You'll need cycle clips to stop 'em flapping. Needs the right cab of course, mine is a vertical oversize 2x12 with an Emi Red Fang and an EV. very 'present' and direct, never gets wooly. Very very versatile, never found a drive pedal it didn't like and I must have tried 30 or so over the years. It is an AB763 circuit but with higher filtering on the power supply and a fairly meaty OT, never found any overdrive pedal to sound fizzy as mentioned above, apart from an Xotic BB Plus but it sounded like that through everything, it was the pedal not the amp.
I also use my Ceriatone OTS similarly, using the clean channel only. very good but not as good as the EZG. Not quite got the bass response.
... But bettered, as a pedal platform, by the superb Carr Rambler...
