It get's a hell of a lot of use because it's so handy, I run mine on batteries and just cart it off to a room nobody's using.
It has a high WAF* as it looks more like an old valve radio. So I can leave it in the front room with no complaints.
If it got nicked I'd buy another one probably.
*Wife Approval Factor
Honestly, for a late night sofa amp, the tiny (and cheap) Blackstar Fly 3 is the best solution i've found (and I'm not a huge fan of the Blackstar sound). The quality isn't as hi-fi or big but I find I "play" it like my normal (and much more esoteric) rig. This is more important to me.
It sounds great , I love that its lightweight and has a very good pseudo valve amp 'feel' thing going on. It also reacts really well with pedals. I'm really happy with it.
The thing that swung me getting it was the two separate amps at once thing, as I'm going to go for a Allan Holdsworth/Eric Johnson type setup and sort of switch between a distorted lead sound and clean sound, both with delays, but be able to have both the trails still spilling over.
My only slight issues are that the amp doesn't have that much gain without the boost being on ( which isn't that much of a problem, as you can just switch it on ) and that the boosts themselves ( you can choose one of three via attaching the amp to the computer) don't have any parameters other than volume . Tho, I tend to use my own pedals anyway, or just the mxr micro amp type one.
I'm not sure the thr100 is really anything like the other thr amps? As they're just plug in, loads of fx ,sound great ,have presets boxes. Where as the 100 , is just a good sounding amp.
@guitarmangler - thanks mate and an interesting review...
Did you buy either of the Yamaha cabs, and how do you find the loop ?
Currently keeping an eye on the classifieds for some type of cab , as I'm just playing through the dg's speaker at home .
Fx loop on thr is switchable for series or parallel, and you can run fx to each amp with some stereo trs jacks ( which I do need to pick up).
I've only had it less than a week, but I definitely like it.
Unfortunately I didn't have time to try a smaller cab, but I don't doubt it was the amp that sounded so good since I've heard other modellers through similar cabs and they don't sound anywhere near the same.
I really liked the dual-amp set-up, I found that very useful. Ross mentioned something about the FX loop not being ideal for that though, I can't remember exactly what... worth asking.
If I was in the market for a new gigging amp it would be at the top of the list.
