JM build | Pedalboard plans
So IC, is that a £700 combo with no 8 Ohm jack?
Dave.
You might be better off with something other than a V30. I had one in a Classic 30 years ago it I didn't like it - it sounded harsh.
I'm not a fan of the C30. It sounds good which is why I bought one as my first valve amp but it is horribly constructed and will be a nightmare to fix if it goes wrong. Personally I'd sell the C30 before it breaks and get a Hot Rod Deluxe.
Even if it doesn't go wrong it will cost you a lot more to run long term. It's chews up EL84s at a phenomenal rate. I used to have to replace them at least once a year - and you have to buy 4 of them so while they are cheaper valves it costs as much to revalve as something with 2 6L6s. A set of 6L6s used to last me years in my HRD.
So, it switches the transformer to an 8R tap but leaves the internal speaker connected? If so, weird!
BTW, whilst talking of things weird? AFAICT the new Blackstar ID Core 100 and 150W combos do NOT have the facility to connect external speakers.
I had assumed they used the same class D "block" as the ID TVPs which seem to have proved pretty bombproof?
I still think the new combos will prove to be good value, light and versatile amps, if only as a backup/spare but the inability to connect to your 4 Ohm 4 by 12 will surely put some players off?
Dave.
My guess would be that the ID blocks were too expensive for the Core series. Let's hope they're as good...
