Delays, where do you put yours?
mike_lmike_l Frets: 5700
Liking quite a lot of gain and drive I find a delay before the amp (or dirt pedals into a clean amp) gives me a horrible muddy mess.
So for me,in the loop, or after dirt pedals works best.
Where do you put yours?
  • RolandRoland Frets: 8754
    edited July 2016
    At the end of the chain. I want it to repeat what I've said what I've said what I've said, rather than sound as if I'm stuttering
    I like my echorec after my fuzz but before my overdrive.
  • Right after everything except volume pedal - after swirlies, too. I tried both ways but prefer swirlies into delay, it is slightly messier.
  • richardhomerrichardhomer Frets: 24849
    If I'm using an amp with a loop - then in the loop - tough after the volume pedal.
  • merlinmerlin Frets: 6724
    When pedalled up, I have everything in front of the amp as I don't have an effects loop. Delay goes at the penultimate link of the chain, before reverb.
  • vizviz Frets: 10720
    In the loop I have delay>chorus>volume
  • slackerslacker Frets: 2254
    I run the amp on the verge of breakup and use overdrive pedals. The delay is last in the chain, well theres a tuner after but you know what I mean.
    I personally view getting a guitar sound as a variable thing. One works with what you've got and within each application. I dont like delay with really overdriven sounds so if I'm recording I'll run the amp into saturation (with an attenuator or a ZVex Nano) and use no pedals. My attenuator has a loop but I dont like a delay in there. Hence no delay for saturation.
    If I have the time and space I'l run two amps, one 'dry' overdriving and one clean with pedals.
  • DesVegasDesVegas Frets: 4604
    After fuzz and overdrives, before reverb and tremolo and a rat into front of amp
  • TitchTitch Frets: 45
    In the loop,
    None of my pedals have a loop, so last in my chain, or second-last if i choose to use the Danelectro FAB Echo.
  • KylefKylef Frets: 1061
    Last but before reverb.
  • professorbenprofessorben Frets: 5105
    I've got one on my board, one in a spare briefcase type thing, and one in an old tesco bag in the garage........
    that beats the "inside of an old Valvestate combo" were I used to find pedals after a few years.
    This for me also!  lots a pedalz > DD6 > HOF > teh ampz. simples.
  • Fuzz / wah/ dirts/modulation/DELAY/verb - split to two amps for stereo effects. Also pop modulation and tremolo into loop of delay (Quicksilver Blackbox)
  • cj73cj73 Frets: 1003
    I like my delays after the played note
  • hugbothugbot Frets: 1528
    I like them before the played note.
  • After the fuzz,drive,flanger,chorus and sitar pedal but before the reverb and trem.
    I might experiment after reading this though
    Instagram is Rocknrollismyescape -
    FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
  • stefken147stefken147 Frets: 51
    Usually after drives and before verbs. Having said that I once ran a carbon copy before dirt for some more adventurous sounds. Running delay after verb can also work well.
  • EHX mel9, fuzz, OD, chorus, phaser, delay, delay, delay, reverb (you can never have enough delay pedals) :)
