Funny you should ask this! I am in the process of clearing up and re vamping the "studio" bedroom. I pulled out a 4 way P strip and was shocked (almost literally!) to find the white plastic had "evaporated" around the mains lead entry exposing the live conductor. This strip powers just a couple of Tannoy active monitors and there is no sign of overheating.
I had one crumble away the same about 2 years ago but that lived back of the fridge and I put it down to mild heat.
Yes, these are just Bargain Store jobs at £5.99 but I am careful to keep the loads well under 300watts or so, but then if I paid £10 or more for a 4 way how do I know it won't go the same way?
I have contacted my local CCouncil so that I can send the strip to Trading Standards.
Dave.
Might even suggest it's been tested to a standard...
Nil Satis Nisi Optimum
Brennenstuhl or RPP if you want it to last and be legal. Any old crap if you don't care.
line 6 G30
I see absolutely no reason to believe that a 6 quid, basic, unswitched 4 way diss strip should be anything other than safe. I would never suggest them for arduous field duty nor would I ever load one to more than a quarter of their rating but they should run a couple of small active monitors, a wee Berry mixer and a USB hub PSU all day long, forever!
In any case the problem was not loading or mechanical stress it was the plastic de-naturing and I don't care if you have a degree from the IEE you could not have predicted that!
I shall now of course buy more expensive strips but how do I know THEY won't go the same way in 5 year's time?
Dave.
I'd avoid the very, very cheapest ones, but your average stuff from big name supermarkets is fine, decent quality plastic and heavy enough brass parts.
I always check mine and run the whole band off an RCD.
Buy 10 amp or 13, never 3 or 5 amp unless you can be sure those ones will only ever be used for very light duty
I see no reason to take such a thing apart? In any case many are blind riveted or in this case, tamperproofs.
I would like to stress once again! This is NOT a band/gigging situation but a fixed site, domestic very low power use.
All my power is on an RCD and there is an additional RCD 13A outlet in the kitchen for kettle and toaster.
Dave.
job done
http://www.raygrahams.com/products/118615-proplus-4-gang-switched-wall-socket-converter-13-amp-dev055665.aspx?pv=37305&gclid=CNr_sLDAic4CFQq3Gwod42QNRQ
Got something similar in my kitchen. But how do you know THAT plastic won't crumble?
Dave.
You need one of these.
Only £705.
But I wouldn't recommend it.
If you are gonna go down that route I'd suggest IP66 sockets at least.
Even then they are not designed for portable use.
Plastic is pretty brittle on those too.
I plugged my new DSL5 into one at home and it was really noisy. If I plug straight into the wall it's totally fine. It's not a dear one, but it's not a cheapy one either.
