Feedback
Double hotcake
Or just get 2 good singles ;-)
It's not remotely "flavour of the month", but it is about the most flexible dual overdrive anybody's made to date. Built like a tank, sounds great. It has independent inputs and outputs for each channel, so you can use it effectively as two totally separate pedals that share a box if you want to, or else just ignore the extra sockets and run it like all the other two-channel cascading ODs out there. Channel B has a very flexible EQ function that uses a static phase shifter to cut and boost different frequencies in a way that simulates what can be done in the studio with dual mics, so you can get some sounds that are reminiscent of Led Zep's studio albums. Loads of tonal variation.
As if that wasn't enough, the pedal is built on multiple PCBs, with all the power and EQ stuff on one board, and the distortion-related stuff on separate ones that can be removed and replaced with any of a whole range of different flavoured dirts- OD, distortion, fuzz, octave fuzz, clean boost...
http://www.foxroxelectronics.com/ZIM.html
1.) The vastly underrated T Rex Moller - can be bought cheap
2.) Okko Diablo - one of the best I used live
soundcloud.com/thecolourbox-1
Twin Stomp do a dual OD and a boost+ OD.
Z Vex do a few, the Box of Rock being the most ubiquitous.
How about the AMT SS11a - its a valve based preamp pedal with 3 channels?
1) Clean with its own EQ, level and gain
2) Crunch channel with its own EQ, level and gain
3) Lead setting which shares the EQ of the crunch, but has its own level and gain
My music:- https://soundcloud.com/hubobulous
I agree with Dr. Sporkenstein, only he said in one line what it took me two paragraphs to say.
...and he probably understood what was going on inside. I just liked the little stripey things on that lovely green PCB.
Stacking three together results in a surprisingly good metal sound.
Although I have yet to try one myself, I thought the demos of the Møller sounded really good.
I said maybe.....
