Hi, here's a summary thread of my present build. It's another bass for our old-gits-band's bassist, Pete.
Still a little obsessed with Jack Bruce, Pete's asked me to do a custom build in the style of JB's EB-3. I say 'in the style of' because he wants certain changes (34" rather than 30") and I want certain changes (neck dive avoidance features, through-neck, fancy top, mudbucker alternatives, etc,etc). Happily Pete isn't a purist
There's a detailed build thread on Basschat, but I'll pop a few WIP shots up to present if anyone's interested. Shout if you want any more detailed 'what and why''s
To offset the extra neck length and short horns, the bridge will be set well back and the top horn is further forward than an SG bass:
Fancy mahogany for the top. Will be stained purplish red:
There's always a first time for everything. I'm going for conventional wings and joined top!
Some chambering to reduce weight. To help the balance, I left the top left hand unchambered:
Wenge veneer demarcation for neck and top:
Basic components glued:
I'll post a bit more of the progress shortly...
Truss rod installed, fretboard glued with maple demarcation veneer and neck profile rough finished:
Wings added to headstock, 'swifts' inlays cut and installed to ebony ' in the style of' plate:
Pickup chambers forstnered and chiseled:
Volute shaped:
Next post will bring it up to date. Thanks for looking!
Frets and dots installed:
Body dyed with (of course) ink. This uses raspberry calligraphy ink to give just a hint of purple in the cherry red that Pete is after. Initial finishing in tru-oil. This will eventually be gloss varnished for the body and headstock, leaving the neck tru-oil slurried and buffed in my stained wood variation of @WezV 's excellent method :
And the first gloss coat just put on this afternoon. Standard polyurethane varnish, thinned a bit with white spirit and wiped on with a microfibre cloth:
Thanks for looking, folks
I was thinking the top fret access was going to be a bit limited, but then if it's for an old gits band, it's probably fine as you'd never want to play up that high anyway.
And that got me thinking ... I wonder if you could design a bass where nothing above the 5th fret was accessible. I could see a lot of guitarists buying one of those for their bassists.
(Full disclosure: I am a bassist who regularly plays above the 12th, although 95% of the notes I play are much lower down).
It's actually a fairly easy reach to 21st although 22nd is a bit of a stretch. Having said that, Jack Bruce's EB-3 only had 20 frets anyway...
Thanks, Jez
Yes. I'm discussing on the other forum whether I can incorporate a few more choke options by putting in a 6 way rotary rather than 4. At worst it will be as the EB-3: bridge only; both; neck only; neck with choke.
At best it will be: bridge only; both; neck only; neck through full primary coil choke; neck though 1/2 primary coil choke; neck through full secondary coil choke.
With the cavities, is it forstner bit then hand work with a chisel or similar?
Yes - both pickups have generous skirts so this is by far the lesser risk way When I am putting in pups with no pickup ring, it's template and router... and crossed fingers
Flattery will get you everywhere, Deadman.
Thanks - very much appreciated
I'm sure there are better and more accurate explanations but, from a practical point of view, the above is fairly representative.
Feedback
Sometimes it goes a bit squiffy at this stage, but at the moment this is the front:
...and this is the back:
In both cases they only had one flattening and one of two thin final coats. What will often happen at this stage is that something will squiff, in which case it is another flattening followed by at least two thin final coats.
