Audio interfaces
I want to make some recordings of my band to use for demo purposes and we want to do "live" recordings to begin with rather than multi-track everything.  My thinking is that we could just set up some mics in the room to record each instrument and use an audio interface of some description to feed it all into Reaper.
Now we've sort of done this before using the USB out on the behringer mixing desk we've got and the problem is that when it comes into Reaper it's all mixed down to one track making any further mixing adjustments impossible.  I've looked at other interfaces specifically looking for ones with multiple outputs and have found things like the Tascam US-16x08 (http://tascam.com/product/us-16x08/) which boast 8 outputs but I can't tell if this is referring to the 8 line outputs or whether you can capture 8 separate channels simultaneously in Reaper via the USB connection.
I suspect it's the latter (which would be great) but I'm struggling to find a clear answer.  Can anyone shed some light on this and, if it's the former, suggest something that would actually do the job?
Cheers!
  • Yes, the 16x08 will give you 8 independent inputs into your DAW. Other options would be stuff like the Presonus 1818VSL (which has ADAT ports for expansion, so you can get another 8 mic inputs in addition to the onboard preamps).
    <space for hire>
  • RedRabbitRedRabbit Frets: 486
    Thanks for clearing it up.  The Presonus looks a safe bet for not much more cash and I'm guessing the potential for extra inputs would be handy if we wanted to mic up the drum kit properly in future.
  • spark240spark240 Frets: 2090
    Presonus stuff is good.
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • AvalonAndyAvalonAndy Frets: 326
    edited February 2019
