My YouTube Channel
Use the amp to generate the tone and volume you need for the mix on stage, do the rest with the PA.
I like the SM57. It just works.
If you have more than one speaker like a 2 x 12 then always mic the one furthest from the drum kit.
Angling a mic like a 57 away from the drums, with the 906 or 609 though it's not necessary.
I will have a look at those suggestions as I don't want to be playing any other gigs without the guitar going through the PA.
I'm not a fan having no (or almost no) stage level and relying purely on monitors to hear yourself either - at least not in a conventional rock band context.
To me it works best when the stage sound is well-balanced in itself so everyone can hear each other - which can depend on amp placement as well as volume - and then if that isn't enough for the room, do the rest with the PA. You really don't want to be trying to fill a room with your guitar amp if nothing else is at that volume.
I've just been discussing this with @shugz. Too compete with Vox, bass and drums through a PA you need a lot power in your amp to compete. Last night I was using a 2x10 18watt tweed. It's a credit to the volume of that amp that it could keep up at all. But all in all the sound was more like a competition, a tad frustrating.
Some guys take the mic;ing up stage volume thing too far and basically play so quiet on stage it's all PA and no amp volume but that's not a good way to go in my opinion unless your using no amp and on an Axe FX or similar ....... Better to set the amp just under where it needs to be in the mix wise and use the PA for the last 20% ..... otherwise turning up the guitar on the desk will actually result in turning up the drums in a typical pub scenario
As @Danny1969 says, let the PA do the last 20% or so - it should have the power/clarity to cover it better than your guitar amp, plus whilst you may think you sound great the mix at the back of the room is rarely the same.
FWIW - the RedBox is brilliant, I've used mine for all sorts (plus you can use your pedal board into it as a last resort if the amp fails - the speaker sim is... alright). I've also used the Superlux from Thomann, which does sound better IMHO than an SM57... but then I've never liked Shure mics very much. Mics *can* sound better but the RedBox takes any random variation out of the equation and makes setting up *VERY* quick.
Sorry if this thread was the wrong place, but the comments just stirred my need to say something!
