One interesting fact which may affect your decision - if you buy the bits to do it yourself and the power supply fails and damages the motherboard (or other components), the warranty will only cover the power supply and anything else that went up in smoke is a write-off. If the same happens when you bought the machine pre-built, the warranty will cover everything.
I only mention this because I've had a number of PSUs fail over the years. The moral of this story is to always spend a decent amount of money on a good PSU that's less likely to fail; don't cheap out on it...for a gaming machine, expect to spend at least £50.
https://www.scan.co.uk/info/scansure
I've built my PCs for years and never had a problem.
It had a 3 year warranty but everything was fine with it.
The PSU failed last year and I replaced it with a modular EVGA one that was on special offer.
Only other change I've made over the years has been as SSD for the primary drive, using the old 7200rpm drive as a secondary drive for photos etc, and have an external hard drive as a backup of that one.
Recently the computer has started freezing randomly at times, usually when using the internet, but I think that's a Windows 10 issue rather than a hardware issue. I'll do a clean install when I can be bothered (system restore didn't help and a couple of other fixes have so far made no difference)
If I was buying now I'd go for 16GB RAM and a GTX 1080 or last gen Titan
On the other hand, I built my most recent PC myself, and it worked perfectly, building isn't complicated if you can handle a screwdriver and plugging in some cables.
http://www.tomshardware.co.uk/nvidia-geforce-gtx-1080-pascal,review-33557-10.html
If you look at cards from 5 years ago some of them were over 600W:
http://www.tomshardware.co.uk/charts/2011-gaming-graphics-charts/3D-Power-Draw,2678.html
Newer processors use less power than old ones as well. A 6th gen i7 (6700K) has a maximum power consumption listed at 95W. The first gen i7 was 130W. I think the 7th gen desktop processors are due in January and will probably knock a few more watts off of that.
You want a good quality power supply but it won't need to be as high capacity as it would have been a few years ago.
I spec'd up a pc with a z170 a motherboard, i7 6700, 32gb 3000mhz ddr4 ram, 500gb ssd, a 2tb hard drive and a be quiet! Dark rock pro 3. Came to about a grand.
Add on a last gen graphics chip from the used market and it'd be a beast for photo and video editing and play games if I wanted it to. It would also have an M.2 slot so I can get mad Pci-e speeds in the future.
In fact, although it's not amazing, the Intel 600p is about the same price as a normal ssd but offers more performance still (not like the Samsung 950 pro though). So you could probably squeeze one of those in as main drive.
Mad. I still feel too scared. Especially as I'd use it for work.
Best reason for tidy cables (other than aesthetics) is for when you want to upgrade anything you're not wading through a jungle of cables every time.
