So a Vox AC15C1 is the latest version 1x12 and AC15C2 is the 2x12.
Bandcamp
Spotify, Apple et al
There's an AC30CC2X in the shop today, with the Blue speakers. It sounds *fantastic* - totally wipes the floor with the "Heritage Hand Wired" version that's also in (and for what it's worth, is not hand wired…) and the Blackstar Artisan 30, which sounds like an AC30 with all the life and character taken out.
The CC2X is probably my favourite modern AC30 now - it's not the closest to the original, the Korg reissue AC30TBX is that - and has the wonderful Vib/Trem circuit - but it's the best combination of sound quality and useful features. The current (and genuinely) Hand Wired version is well-made and sounds great too, but doesn't have all the cool extra stuff.
However, I was a moderator on the Vox forum and re the Custom Classics there was a massive furore (HUGE!) re the 'vox chinese celestion blues' that were made with the 'wrong' speaker cone material, and people were upset that Vox had misled people - especially as marketing pics originally showed the UK Celestion Blues which was hugely misleading. That's why the Alnico Blues in the new AC30C2X have the correct cone material, and these speakers now sound like the UK Blues.
But re the Custom Classics, I understand that its a pig to change tubes as you have to drop the whole chassis out....or have I got that wrong?
The CC is a bit of a pain to change valves on, yes - to slide the chassis out you have to undo four awkward screws under it, and on the very first ones you have to undo the speaker wiring… not kidding.
The C is not much better though - unless you remove the fairly unnecessary metal grille in the back, you have to take out no less than seventeen screws to get into it. Removing the grille isn't really ideal either since it leaves the valves a bit unprotected.
You can fix the CC too - if you fit two extra slide rails above the shelf, you don't need the screws and then it's as easy as a vintage AC30 - in fact easier since you only have to take out two screws not four from the back panel.
Harley Benton G212V
[/stuck record]
V30s, but you can always change one or both later.
Bandcamp
But I just felt that the Greenbacks suited my style of playing and type of music a little better, and were more 'comfortable' to play. If I was buying one then I think the AC30C1 with Greenbacks would be the one I'd go for...and it's cheaper too. Sadly, I have no room for one, can't carry the weight any more, and have no need for one from a gigging perspective. But maybe one day I'll win the lottery, have my own sound-proofed studio/rehearsal room...and then, who knows!
At that point, the first thing you notice with Blues vs almost any other speaker is that big, pushed mid-mids at like 800Hz, and how connected to the notes the speaker breakup is.
Greenbacks have a much wider sweetspot volume- and tone-wise and are more adaptable, though.
Bandcamp
Mine is sadly one of the early ones that I need to have modified so the speaker cables don't have to be disconnected to change the tubes (incidentally, whoever thought of that really is clueless). It needs two people to carry it from the car boot but...it's just such a wonderful sound. Sat on the edge of break up and digging in a bit on the strings makes it sing. I've never heard of this mod actually - is it quite common? Seems to have completely passed me by.
This is an original, you can see the chassis shelf slides into the slot between the two blocks on each side.
http://mccarthyorth.smugmug.com/photos/539300403_s5bUR-L.jpg
All you need are two strips of wood and four woodscrews and you can make your CC like that.
