It allows you to convert from a wide range of input formats to a large range of output formats. For example, you can write in Markdown (easy to edit, lightweight markup language) and then render to PDF via a LaTeX template (so you can get pro-quality typesetting).
Note that Pandoc is just the converter - you still need an editor. I've found Atom to be very nice - and it includes a Markdown preview engine so you can have an (almost) WYSIWYG authoring experience.
JM build | Pedalboard plans
I suggest that the key is to follow the particular journal's style guidance, more than worrying about the software you use.
Although, of course, most prefoessional/academic bodies forgive an awful lot for good content that's easy to peer review.
It costs but not much -- it's cheap. Free trial to get used to it because while it shares similarities with Word it is not Word, or LibreOffice. So you've got to start using it to see what's different about it and how that would work for you.
Work through the examples they give you just to get the flavour of it.
I couldn't imagine using anything else for serious writing.
For me the huge, huge plus point is the way you can organise your project within it. And a dozen other things too.
EDIT -- just to be clear, once you have finished your project, paper, thesis, novel, stage play, whatever, you usually then export that to something like LibreOffice or Word literally as the last thing you do. Scrivener is for making the writing of the damn thing easier.
EDIT 2 -- @Fretwired ; Scrivener for Windows has been as solid as a rock for the last couple of years. @Hertz32 stability was hugely important for me when I switched to it. No problems whatsoever. In fact you have many back up options. Mine are to save my writing projects to Dropbox every few amendments -- happens behind the scenes automatically and unobtrusively -- and to make a zip backup in a local folder on exit. The program itself hasn't shown me any bugs -- just a fucking quirk which has now been sorted in a more recent version! And I've used it on two substantial pieces of academic work (over 80k words for one; 15,000 words for the other); one 60k piece of non-academic work, and countless smaller pieces. I've never lost a word.
