As for the radar thing, I've seen multiple videos showing it works, but I wouldn't want to rely on it!
One day he did that without noticing that the little warning light that said 'ABS' on the dashboard was on, and drove straight into the back of a stationary car.
Until fully automatic cars become standard it's probably wiser to drive as if you don't have anything like that...
Seems to work quite well - as I was driving the other day, and there was something on the driver's window, which caught my eye - so my eyes were off the road for a split second - I ended up veering the car left towards a car parked in a "P" area on the side of the road - car beeped - and I saw what was happening and corrected.
Wasn't even really a close call, but was nice to get the alert.
ABS def works - not for stopping tho - for continuing to steer whilst trying to stop!
The last Octavia I had had automatic braking; I found it a bit naggy and over-sensitive. Probably quite useful if you're easily distracted.
However, what a driver cannot do is control each brake at each wheel independantly. So there could be a situation where a wheel is locked for the driver with no ABS, which in the wet is very ineffective, and for the driver with ABS that wheel could be released without releasing all 4 wheels so that it could be used to brake the car again. The driver with no ABS would have to release all 4 brakes to release just the locked wheel.
R.e the radar auto-brakes. I think the key is to know the limitations of the system. Some only work very low speed.
I always assumed that a Merc braking for no good reason in the outside lane was just being driven by a twat, but I will have to revise that opinion now.
They'll never be as good as proper Horse Cars. People say they can't tell the difference but I swear that whenever I've been in one it's faster and smells different. I'll stick to Horse Cars until they have worked out how to do Motor Cars properly thank you very much.
Probably, though they might not have noticed it.
Swerved violently on a wet motorway to avoid a collision. Car started to rotate and before I even started correcting it had engaged "tapped" the rear inside brake and straightened it up. It took me a good 10 seconds to work out what had just happened, in between deep breaths.
I've driven competetively and consider myself reasonably adept but the ESC did a really good job that I would have struggled to handle safely without.
First, at a guess the big blip in 40 and 41 will be due to blackout conditions during the blitz.
Second, I'd love to see a version of this graph that takes into account population and average number of miles driven per person per year - suspect the decline post-1970 would be even more dramatic!
Bandcamp
Spotify, Apple et al
A few years ago there was a lot of snow in Birmingham, I took the car to an industrial estate and just practiced deliberately slipping the car sideways - only a half dozen times, but I figured if I just knew what it felt like when you're behind the wheel, if it ever happens for real I'd have a better chance of not screaming and throwing my hands in front of my face.
Bandcamp
About a year later he was going down a snowy hill at about walking pace, had to tap the brake when a pedestrian stepped out and the car started spinning. Fortunately he remembered my hilarious suggestion, pulled the electronic handbrake and the car straightened itself out and stopped. Apparently it made very unhappy noises in the process but you could feel it braking each wheel independently. Can't do that as a driver...
That's incredible.
