Crossing amp streams
DesVegasDesVegas Frets: 4592
Tonight i played a little pub gig and set my amp up where the guitar should go and played in front of the bass amp.
The title could also be Setting Up Without Monitors
  • ICBMICBM Frets: 72521
    I've done that recently too. At a venue I often play with house backline, the better guitar cab is on the same side of the stage as the bass amp - the guitarist wanted to use the better cab, so I just stood on the other side of the stage and ran a cable to the bass amp. Got enough in the monitors to hear what I was doing and was good to go.
    It actually worked better than the time he used the other cab and we stood in front of our own amps - but the soundman made us play too quietly and the monitors weren't set right, so we couldn't hear each other.
  • Slade used to use 4 4x12's for their two guitarists with each guitarits  amp running one 4x12 either side of the stage
    www.maltingsaudio.co.uk
  • JeremiahJeremiah Frets: 631
    Sorry couldn't resist
    Even cleverer than that, before they had the Marshalls they used two AC30s, and had them linked together with a special cable so each amp was driving one speaker in its own cabinet and one in the other amp.
  • FezFez Frets: 529
    No no no now I need more speaker cabinets.
    Don't touch that dial.
