Never tried one mate, but it should do the job. The Timmy is highely regarded as a transparent overdrive with one of the best EQ sections on a drive pedal.
However you may find that the DRRI isn't as bright as I found it and this is all null and void
Feedback can be found here http://www.thefretboard.co.uk/discussion/comment/908933#Comment_908933
Well I have only tried it with TV Jones Powertrons on a Gretsch EM Doublejet, and the Powertron is a fairly dark pickup. I imagine my Tele will sound pretty bright, but I like a bit of bright chime and Fender guitars & amps are obviously a perfect match.
Sorry for hijacking your thread!
Not a problem mate.
I played a Tele into the DRRI and it was harsh, even with the bass on full and the treble on zero. It needs to be pushed into levels that I couldn't hit at home, which meant that overdrive pedals sounded horrible with it; however I know this is not everyone's experience
If you've not tried the Gunshot you're in for a treat. That stacked with the Peacekeeper into my Sportsman gives a lovely lead tone.
Have had a gunshot before but it was into a different amp at the time and it didn't quite beat the Kingsley Jester I had. I am looking forward to seeing what a mid scooped amp will sound like with it and think it's the perfect answer to the Imperials rhythm channel
I have a couple of Pedalworx Texas Two Steps that used to sound great through a Fender Super Reverb. Sadly that amp is gone , still sound good through a Musicman 210rd though...
there's a Timmy V1 in the emporium.
It's stunning.
You'll thank me for this.
