I am doing a pedalboard rebuild with a Pedaltrain Novo 24.
I was swapping my wah (Hendrix Sig Crybaby) and the slats on the Pedaltrain board don't allow flush mounting. So I went to screwing the screws into the pedal further to see if I could get them a little flusher. So I've snapped the screw head off and the remainder is jammed in the pedal casing.
WUT do?
I've since ordered a new wah (white sparkle) and an EWS wah plate so it doesn't happen again...
Shall I try drilling out the screw thread that's stuck in the wah? I like the Hendrix one, but Dunlops feet arrangement makes mounting them on boards an absolute hassle... Will drilling it out work? I think cutting the remainder off first and then drilling with 1/8" bit may work? I've then also ordered a replacement base plate so I have some new feet and screws. (I'll swap the GCB-95 base plate with the Hendrix one, as that's ok.)
Luckily everything works fine, so I may leave it, but I'll probably cut a slot, undo it and replace in time.
