As long as the case, face, hands are OK the movements can usually be replaced no problem.
I "think" TAG's use std ETA movements which can be had for £20 upwards.
To disassemble is as straight forward as open case, remove stem/crown, remove movement including face and hands from case, remove hands and face from movement. Reassembly is the reverse.
Obviously there's a bit more to it (including very steady hands and a jewelers lupe) but it's fairly simple really.
Personally I like Seiko Automatics, real watches (all mechanical) for not much money
