I love the amp I have, I really do but because of the fact it is lower powered it is not versatile. To gig with my band I have to use a two amp set up so I can have my delays and modulation through an amp with a little more clarity and cut.
My role in my band is as chief noise maker and in order to do that I need a little bit more versatility than just the beautiful drive tone of the tweed.
The reason I'm thinking of going higher powered is to be able to use one amp.
Volume isn't really the consideration as I have loads at 18watts. I can gig with my two amps all day and not have to worry about volume. The reason for thinking about a bigger amp (watts wise) is for a touch more clarity and a little less compression. Of course that will change my tone though.
Perhaps I'm hoping for an amp that can do it all but I guess there has to be some compromise in all amps?
