FS: SuperChamp XD / Chord CV-30
Collection is from Teignmouth, Devon. I'm happy to discuss postage at the buyers cost and risk (it needn't be expensive and I'll do my best to pack as well as I can).
Chord CV-30 - £110 £100 £90 £80 £75 collected. Happy to discuss postage
Chinese made, 1x12 valve combo. 2 channels, spring reverb, FX loop. 1 x 12AT7, 2 x 12AX7, 2 x 6L6. That's all the good stuff - these really appear to be reasonable amps. It sounded pretty good to me when I was using it.
Now the bad stuff - at one point, it had some intermittent problems whereby the volume level would drop drastically. It was out on loan to a friend at the time and he sent it away for repair (I don't know where) and after coming back once with the same problem they then claimed they'd fixed it and it was due to the tracks breaking when the amp heated up. I've no idea if this is true or not but in the limited time I've run it since I haven't experienced the problem. That said, I want this to be an honest sale and therefore this is sold as seen (or described). Even in parts alone it must be worth the asking price but for me it's just taking up space and I need to move some amps on.
Oh - more good stuff: It comes with a footswitch + I have the original 'Chord' badge if you want this stuck back onto the front of the amp.
SOLD
SuperChamp XD - £165 collected. Happy to discuss postage. SOLD ON EBAY
I'll add some photos later on this evening but having just bought a Hot Rod Deluxe I need to move another amp on. It's been a tight battle of which amp remains between this and my Special 6 Ultra but the poor little SuperChamp has been edged out at the minute (I might always change my mind!).
A great little amp which remains as stock (I never did quite get around to switching out the speaker). A small mark to the Tolex in the top (I'll try and cover this when I add some photos). I'm happy to post at the buyers expense - I'll package it up as best I can and send a photo before it gets despatched.
Sessionette 75 2x10 - £165 £150 £140 £135 collected. SOLD ON EBAY
I know these amps can divide opinion (there's plenty of discussion about these both here and elsewhere on the internet). Solid state amp. 2 x 10 inch speakers. Spring Reverb. Personally I like them a lot and I'm divided about selling this but it just isn't getting the use it should and I'm trying to purge some gear (trust me it doesn't happen often!). The pots were a little scratchy when I got it but I've recently given them a blast of deoxit and it all seems good now. Although not as portable as the 1x12 version, the 2x10 was considerably lighter than the 2x12 and has a great sound. The 2x10 also seems to come up for sale less than often then the 1x12 so it could be your best chance to snag one ;-)
Comes with original footswitch which allows for channel switch, reverb and channel mix (a great feature that allows you to blend the clean and overdrive channels).
Untested Session FS:3 footswitch (sold) - sold as seen although I can't imagine there could be much wrong with this apart from a break in the cable. Let me know if anyone want's more photos.
£12 including UK delivery (assumes PPG but happy to add 3% for regular PayPal).
